Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
15-08-2011, 10:54 AM | #1 | ||
hi,
I'm after some advice on how to get a good 0-100kph time. I've been using a friends private driveway to do some tests. I'm finding that if I plant the throttle all the way, I just get wheel spin. So I have to be gentle initially and then build it up, but that gives me a slow start and initially the revs are below 3000rpm, so out of the power band. If I stall up the convertor to 2500rpm, again I just get wheel spin. Is there a better way to do this, or do I really need better tyres and an LSD? I'm getting a consistent 7.4s 0-100kph on both BP ultimate and gas, using the OBD port to some diagnostics software. I have a definite dip in power around 3000rpm and need a tune, but can't justify the cost at the moment. Cheers.
--------------------------- Falcon BA XT 5.4 V8 3v |
15-08-2011, 11:35 AM | #2 | ||
It's not illegal to accelerate to 100 on a freeway with a 110 limit
Last edited by SpoolMan; 15-08-2011 at 02:12 PM. Reason: You have an issue take it via PM. |
15-08-2011, 11:44 AM | #3 | ||
Best to head to the Drag Strip safer and they will prep the track and reduce the chance of wheel spin.
Try stalling up and mashing the brake pedal on take off. Drop the rear tyre pressures down to 24psi pump the fronts up to 50psi. Stall up to a lower rpm? Leave the handbrake on part way until out of the hole then take off. |
15-08-2011, 11:54 AM | #4 | |||
you want to check that, excessive acceleration is what its called and yes they will impound you car for that... LOL anyway, this is being tested on his friends driveway ;) so help the fella out what tyres you running? might help to lower the psi a little.... maybe even a small burnout to warm them up a tiny bit Last edited by SpoolMan; 15-08-2011 at 02:13 PM. Reason: edit quote |
15-08-2011, 05:49 PM | #5 | ||
Thanks, I'll try some of those tips and head up to my mate's farm at the weekend for another try.
15-08-2011, 06:14 PM | #6 | ||
Make sure you reset the ecu before your run because if you been crusing all the way to the farm the timing will be on the retard side of things.
Also seeing as you don't have a LSD put some weight in the boot above the right rear wheel. |
15-08-2011, 11:41 PM | #7 | ||
cheers, I've got the gas tank in the back between the 2 wheels, not sure how much it weighs, but expect it's a fair few kg when full.
16-08-2011, 02:01 AM | #8 | ||
buy yourself a second motorcycle for $2000, and you wont have to worry about going slightly better then 7.4 seconds, you will be looking at 5 seconds and lower times.
16-08-2011, 08:04 PM | #9 | ||
If you have wheel spin issues with the single pegger the best way is to get an lsd,no two ways about it.
Single wheeler diffs are for grannys, not good 0-100km times. And good tyres are a must,not expensive just new/newish condition. |
18-08-2011, 12:42 PM | #10 | |||
18-08-2011, 11:37 PM | #11 | ||
Better way to get faster 0-100 times ???
Borrow my car ;) 3.89 @ the track . Seriously though , forget tunes and all that , invest on some really decent tyres under the rear !!! Best bang for buck for acceleration on any car Then start looking at tunes and such .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
18-08-2011, 11:49 PM | #12 | |||
Just slidin'
MD Mondeo - For the family
NP Pajero - For the adventure |
18-08-2011, 11:51 PM | #13 | ||
Performance moderator
Softer springs and dedicated drag shocks..
As said a good LSD and lower final drive.. A whole XR Diff centre maybe ?? If your serious buy some 15" wheels and fit some drag radials 245X15 or so..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
31-08-2011, 09:09 PM | #14 | |||
