22-08-2011, 05:18 PM | #1 | ||
Hey guys.
My friend bought a 89 ea spack, manual, 3.9 The problem he is having is when the car gets to operating temperature and the thermostat opens up it runs like crap, coughs and splutters, But if he revs it over 2 grand the problem dissapears He has replaced alot of things. map sensor, thermo sensor,all of the vaccum lines etc Put a brand new thermostat in and it still does the same thing Even had the ecu looked out and theres nothing wrong with it. If any one would have a idea of what might be cuasing it, would be good
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
22-08-2011, 05:26 PM | #2 | ||
sounds like a ignition problem to me like the coil is stuffing up once it gets warm/hot
22-08-2011, 05:32 PM | #3 | ||
He has replaced the dizzy with a brand new one as well as the coil.
22-08-2011, 05:44 PM | #4 | ||
does it have a worked cam in it if so it might be like my EL and run crap down low but once it gets over 2600 it goes way better
Jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
22-08-2011, 06:41 PM | #5 | ||
Nope no cam all standerd,
24-08-2011, 01:50 AM | #6 | ||
try placing your AU injectors in his car if its MPFI
had the same problem in my EA exhaust leaks ?, fuel pressure |
24-08-2011, 11:10 PM | #7 | ||
Will let him no, cheers
