30-07-2011, 07:00 PM | #1 | ||
Formally RED XR8
Hi everyone,
I am having an issue with condensation in my garage at the moment. Unfortunately I don't have any sisalation under the tin roof and I am getting water dripping all over the GTP which is pi$$ing me off. I am wondering if i install a "whirlybird" on the roof would this help fix the problem due to increased airflow in the garage??? Thanks in advance, Greg.
PREVIOUS '03 GT-P Manual, Sunroof, Sat nav, Leather, reverse sensors The only FPV ever built in CONGO GREEN SOLD CURRENT 2012 Manual, leather, sat nav GT 335 in SWIFT GREEN 1 of only 6 manual Swift Green GT’s and 1 of only 21 Swift Green GT’s in total |
30-07-2011, 07:09 PM | #2 | ||
VFII SS UTE
air condition it...then put TV, pool table, bar, jacoozie..
and i'll be over soon! would it be a hot motor drawing the condensation? edit: just an air gap (small) between the walls and roof.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
30-07-2011, 07:12 PM | #3 | ||
our back deck does the same thing, the iron roof gathers condensation and drips down onto the deck, but it's completely open...the deck boards are separated, and it's just railing around the edges.
Is it getting very cold down in Mornington, or does it happen all the time?
----------------------------------------------------- 2012 Focus ST Tangerine Scream Continually having a battle of wits with unarmed opponents. Sez Photo's by Sez |
30-07-2011, 07:39 PM | #4 | |||
Formally RED XR8
30-07-2011, 07:50 PM | #5 | ||
might sound like a silly option, but its simple. rig up a tarp just below the roof line? or even if its a beveled roof get some PVC pipe of a resonable size cut along to make a tray that goes to a drain? as im assuming its gathering right in the top joint as the car sits there slightly hot in the arvo and as it cools and turns to condensation comes back down?
Now Ford-less But good things are coming in 6 months
30-07-2011, 07:59 PM | #6 | ||
These might help, there's a few different solutions in there...Burnz actually said one, but I don't know if he meant it in that fashion...was Airfill (like bubblewrap)...
http://www.gmh-torana.com.au/forums/...ation-in-shed/ http://forums.whirlpool.net.au/archive/1345680 Good luck!
30-07-2011, 08:34 PM | #7 | ||
Its because of the cold weather and the sun hitting the roof in the morning.
A whirly bird wont make much difference. Is the garage door left open over night? That may help even the air temp inside and outside of a morning.
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
30-07-2011, 09:06 PM | #8 | ||
Performance moderator
Ventilation to keep temps equal.. An extractor fan either driven off elect or solar..
Make sure NO moisture is getting under floor etc... A dehumidifier or tarp over car ??? http://www.appliancesonline.com.au/d...FcYNHAoddFxZXw
31-07-2011, 07:32 PM | #9 | ||
Formally RED XR8
I have a side sliding door which opens into my backyard, I might try leaving it open a small amount to see if that helps. If not, I will have to install some sisalation. Thanks to everyone for your advice.
