04-04-2011, 02:04 PM | #1 | ||
Are the Supercars on yet?
When ever i start the ute (on petrol) it shows me the gas fuel level, and then slowly the gauge needle moves up (or down) to read the fuel level after 15-30 mins.
Shows gas level alright when starting on gas. It never used to do this. The gas system uses the standard fuel gauge in the dash. So swapping between the 2 fuels on the go takes a little to give the real level.
A Ford win is a good win! V8 dreamteam 1st: 2012, 2021 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
04-04-2011, 02:44 PM | #2 | ||
Flairs - Truckers Delight
factory dual fuel?
mine switches instantly
04-04-2011, 06:33 PM | #3 | ||
I think it was put on after the ute had been bought but pretty soon after
04-04-2011, 08:49 PM | #4 | ||
They take along to to react because of the buffering Lanky, but yours seems to have developed a wiring problem/short -if you are running on petrol, the lpg should be switched off -maybe its a problem with the relay that switches the fuel gauge between petrol/lpg. Mine does the opposite - it starts on petrol and switches to gas, so it gives accurate petrol reading instantly, then takes a long time to adjust to give the proper lpg reading. I can remember reading in the lpg forum, that you can add a diode somewhere to stop the problem, but they gave no details.
04-04-2011, 08:52 PM | #5 | ||
Yeah i figured the buffering would be why it takes a while to change. might try and have a decent look at the wiring.
05-04-2011, 05:32 PM | #6 | ||
You said it never to used to do this, so I would think the first thing to check is the fuel gauge petrol/lpg relay. They sometimes cut into the petrol tank sender wire inside the kickboard next to your right foot. Trace that wire and you should find the correct 2-way relay. I think the way it works is that when the relay is not powered, it conducts the petrol sender, when it is powered it conducts the lpg sender.
19-04-2011, 08:16 PM | #7 | ||
i'll have a look there too.
