Old 14-03-2011, 11:47 PM   #1
obsesscort
obsesscort's Avatar
Default Escort strut change
Hey guys,
Do mk2 escort 2L struts fit into a mk2 1600 easily? or is there fiddling around involved with strut tops/shocks etc....
Regards,
Tim
1978 Ford Escort Panelvan
obsesscort is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2011, 12:25 AM   #2
Michael McKinnon
Staight swap
Michael McKinnon is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2011, 07:33 AM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Default Re: Escort strut change
the only thing to keep in mind is there is 2 different sizes of strut tops for the MK2 escort.
easy to swap the tops over if required
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2011, 08:37 PM   #4
allanv6gt
Tippy-tronic Free Zone
Different sizes being?
??? Size of shaft thru top mount rubber bush ? (like Capris)
??? 'Narrow' or 'wide' bolt pattern for top bush?
Gurus? Responses pls.
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2011, 10:41 AM   #5
Puzzlescort
Rally Nut
on Mk2 Escorts there was 2 sizes of strut tops, where they attached to the inner guard if you like, the earlier mk2's were the same diameter as the mk1 & capri's in size with the later being smaller diameter
off the top of my head I can remember the exact dimensions apart from saying it is a major difference
hope this clears up any confusion
Old 22-03-2011, 01:57 AM   #6
obsesscort
obsesscort's Avatar
thanks for all your replies guys!
Regards,
Tim
