Old 27-09-2005, 09:36 AM   #31
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Weak !
Just have the radio up loud, go deaf and then you wont have to worry about the beeps ;)
Chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2005, 10:37 AM   #32
lincoln
Blinded
lincoln's Avatar
Yes, the beep is damn annoying. Especially when you reverse out of your parking spot with your seat belt off. Does anyone else reverse with their belt off? I find it easier...
lincoln is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2005, 06:30 PM   #33
Stampy
Posts: n/a
i do and it's legal . The beeeeeeeeepppppppppppssssssssss give me the pippppsssssss.
i don't need to be reminded to put on a belt ,just the light is fine,I don't forget the belt in the AU and it only has a light .
I will find the beeper and cut the wire all i need is a wiring diagram to trace it and disable it.
Old 27-09-2005, 06:59 PM   #34
b2tf
not here much anymore
b2tf's Avatar
Im tempted to do the same, id rather cut the wire than go after the beeper because i think the beeper is the same unit that reminds you your lights are on etc.
RAM 1500
