Back in black
Now I have to do some running repiars on the XR8 while away in a little country town. Now the question I've got is do I have to drop the oil out of the car before replacing the o ring on the dip stick tube where it connects to the sump? Need to know before I leave the bigger town to head to the little town.
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
![]() Join Date: Jan 2005
Not sure, but i have an idea that may help. Measure the dipstick from where it sits on the tube (ie the bottom of the top yellow part) to where the oil comes up to at the bottom of the dipstick. Now measure down the tube the dipstick goes in, and see how far down your stick measurement is. If it's above the part where the tube meets the sump, then you will need to drop the oil, but if it's further down into the sump, then I think you should be right without dropping the oil. Or just hold the dipstick outside the tube and see how far down it goes.
Regulator
Can't comment on the XR8, but it should be the same. On the 6, I have not had to drain the oil to replace the dipstick o-ring. I've had to remove this part a few times when working on the inlet manifold, e.t.c.
Hopefully someone else can confirm but I'd say not as the oil level in the sump should be below the point where the bottom of the dipstick enters.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
![]() Join Date: Dec 2006
Like Bob I have only done 6's and no need to for them
Just be careful no crap falls in the hole |
Back in black
All sorted. I was beaten by the o ring and limited space and no tools while away. Mechanic sorted it.
