Citric Ford
Hi all, I have a AUIII Rebel that I think has a mid-range audio system installed, I put a 8' subwoofer in it today but it's not working, the wiring for the subby is there, but I suspect that this stereo is only a mid-range edition and therefor wont have the programing and/or the capability to drive the subby, does anyone know if it's
1. Possible to reprogram the stereo to high range features 2. Get this stereo to run the subby I've installed if it's not possible to reprogram it 3. If the amplifier that was factory installed into the boot quarter panel for the mid-range audio system will run a subby.... and finally 4. If none of the above will work does anyone have a high range AU Factory stereo and amplifier that they would like to sell. Thanx |
The Monty
the head unit is isnt the problem its the same for all models reguardless off the premium sound or not.
the amp is only avaliable is running a sub to, so there must have been one there previously how do u have the sub set-up/wired? |
#3 | |||
Rob
Yea id be looking into the wiring as well as a problem.
Do you have the stock head unit in? Quote:
Formally kotevski22
If you have a amp there should be two wires for the sub coming out of the amp.There is more info in audio and trim section.
Citric Ford
Thanks for the info, I'll check it out ASAP
This car did'nt have a subby before I installed one, so not even sure if it has a amp.... If it does'nt then that would expain a lot |
Rob
haha, yea that might help. whats the RMS watt of the sub you put in? and i presume you mounted it on the pastel shelf as you got an 8" sub?
