12-09-2010, 09:57 AM | #121 | ||
Just another mock-up..
Fair enough...
It still amazes me how many AU V8 questions still don't have 100% answers..! THanks man.. I'll go do a bit of homework now...!! Cheers
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
12-09-2010, 10:00 AM | #122 | ||
not here much anymore
Just to weigh into the rockers debate, the old black ute had 1.7 YT's off a 220 and it was a 200 motor. The only thing about that car is that it went to Herrods and had a whole heap of work done - it wasnt cammed, but they could have been changed there.
Im not sure whats in the blue ute but I know it's 100% stock, I may even pop the rocker covers off today and have a look. Wouldnt be surprised to see YT 1.7's on there staring back at me as it is a late 02 build.
RAM 1500
12-09-2010, 10:05 AM | #123 | ||
So you reckon the late 200's had 1.7 yella terra's Austin..?
I'll be interested in finding out whats in yours... Cheers mate Kris
12-09-2010, 06:18 PM | #124 | ||
pursuit ute baby
i might do a rocker popper check in my 200.. just to add confusion.
my ride : AU xr8 pursuit ute |
12-09-2010, 07:15 PM | #125 | |||
Cat be Still !!!
I think you'll find all 200kw donks have 1.7 rockers. |
12-09-2010, 08:28 PM | #126 | ||
not all craig...this is the first I've seen...
the ones (3 or 4) that I've seen have had 1.6's..
12-09-2010, 11:56 PM | #127 | |||
Cat be Still !!!
13-09-2010, 12:16 AM | #128 | ||
Now Fordless
Well according to all documentation the 200kw units had 1.6 rockers. They also had a slightly bigger cam so it wouldnt make sense for Ford to downgrade the cam with the next series if they were both using 1.7s.
Ford probably just changed parts suppliers. |
13-09-2010, 08:03 AM | #129 | |||
From what I've found out from another S3 V8 owner (ute), it seems that while the sedans were getting the 220kw engine, the utes were getting the 200kw, but, with the bigger roller rockers, (my engine being a S3 xr ute engine) as his is the same, and he's seen others like it.. Again, Austin, I'll be interested to see what yours has.. Cheers
13-09-2010, 10:13 AM | #130 | |||
Back to Le Frenchy
SII 200kw had Crane 1.6 rockers. 220kw got YT 1.7's. Some late 200 utes got the YT 1.7's as Ford had to use what they had left and it seems they ran out of the 1.6's.
The only way to know if your SIII ute has 1.7's is to pop a rocker cover as there was no science behind what got what.
13-09-2010, 11:26 AM | #131 | ||
So in saying that russ..
What would the benefits (power wise) of the 1.7's on the 200kw engines over the 1.6's..?
13-09-2010, 11:39 AM | #132 | ||||
Back to Le Frenchy
13-09-2010, 02:23 PM | #133 | ||
It's all been covered pretty well by the Pugged one above, I didnt get a chance to pop the rocker cover off and have a look yesterday but will try and do so at some stage.
RAM 1500
19-02-2011, 12:51 PM | #134 | ||
Screamin' it's lungs out!
hi all. dragging up an old thread here...
wondering if anyone knows the build numbers for AU XR8's? more specificly, how many S1, 2, & 3's in auto or manual and in each colour. is just that there's a venom red S2 220kw auto in the family, and i read elsewhere that there were 1954 S2 autos built (but no break down between 200kw and 220kw), and i've now got a silhouette black S1 manual too, and there were 619 S1 manuals built, but i haven't found anything about the colours themselves. thanks in advance! Last edited by BDA Escort; 19-02-2011 at 12:57 PM. |
13-05-2011, 09:45 PM | #135 | ||
hi i have an au s1 xr8 i have just had a cracked overflow bottle fixed after about 4 months. it is going fine but i am still using water (not coolant just water) is this normal or am i fearing the worst of a blown head gasket??? some help would be great
13-05-2011, 10:12 PM | #136 | |||
14-05-2011, 12:10 AM | #137 | |||
RAM 1500
14-05-2011, 04:20 AM | #138 | ||
For those that can't use google:
•Typical symptoms of a blown head gasket may include these: bubbles of air coming up into your radiator (remove cap before starting); a leaking radiator; milkshake-colored oil; overheating; rough running; coolant or oil running from head; spark plug(s) that have a green tint (if green coolant); white-colored or sweet-smelling exhaust. •White smoke from your tail pipe, or loosing coolant through your overflow. Take the cap off and rev the engine, look for bubbles... •A dark smell in the radiator. High back pressure coming though your radiator cap. Sounds like it's not really the easiest diagnosis! |
15-05-2011, 04:33 PM | #139 | ||
na im not using coolant atm becausr of when i had the leaking header tank, didnt want to waist lots of money filling with coolant every time i needed to use the car, is there a sure way i can tell if its blown, it doent seem to be affecting the engines performance and the oil is ok, i have noticed that the water boils after a bit or a drive, could it just be steaming out the overflow?
16-05-2011, 09:59 AM | #140 | ||
Back on the road
Check around the front (alloy) timing cover for leaks. They can corrode badly over time, especially when there is no coolant/corrosion inhibitor used...
How many km's has your engine done?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
17-05-2011, 11:31 PM | #141 | ||
270 on the clock, i will have a check 2moro after a bit of a drive, just thought id mention that im on gas if that changes things
18-05-2011, 05:02 PM | #142 | ||
thank the lord for all is mighty!!!! its not a blown gasket, there is a leak where the heater hoses join to the firewall, its leaking down the firewall on the inside and into the passenger foot well, could almost go swimming in there lol, so im gonna strip it down this weekend and replace the heater box(maybe just the connection) so thanks for your help, much appreciated
27-09-2011, 09:19 AM | #143 | ||
EL SVO
Looking at a 2001 AU2 XR8 manual here in NZ the dealers says the rego states it's a 185kw in one of the engine pictures you can see Tickford wings engraved into throttle body?? so if it's the stock T/B would mean it's 220kw?
It also has one of those horrible twin rear boot spoilers with the black top spoiler which I thought was AU1 style.... Is cheap at 139kms on the clock 18in wheels at 10k NZD(7-8k AUD)but is the RED which I reckon is the worse AU colour...I'm thinking black rims dropped to the ground ,,,maybe a paint tint ??
Turbo terror...... |
07-11-2011, 08:23 PM | #144 | ||
What is the differance between a xr 200kw and a TE 200kw?
BF F6 T1 TE50 XR8/XR6 & FPV owners club of SA Club Vice President www.xrfpvclubofsa.com.au |
20-11-2011, 11:40 AM | #145 | ||
Ford Trim Specialist
Been looking here and can't find, so don't shoot me if it is here somewhere....but how many AU V8's were made (non XR).
Interested to know if there is a breakdown of forte & fairmonts etc??
FORD Trim Master |
20-11-2011, 04:43 PM | #146 | ||||
Back to Le Frenchy
08-08-2012, 01:26 PM | #147 | ||
Hi Guys,
I have put AU series 3 XR8 heads, manifold & cam into a my rebuilt 5lt EB2 wagon. I've been told the ECU has to be reprogrammed and I also need a 90mm MAS and I can't appear to find one in Australia. Can some one give me advice on this Thanks from keno49 |
09-08-2012, 11:10 AM | #148 | |||
5.6L x 2 pilot
As for the tune, It is recommended to get the most out of the modifications that you have made. You have changed the air/fuel conditions of the car with the GT40Ps, cam and manifold. Without a tune, your ecu will provide the same fuel to the engine as it would have in the old configuration (EB), potentially causing it to run lean. Tune recommended. Good luck Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
11-08-2012, 04:01 AM | #149 | ||
Boost is here!!
Just thought id throw this out there seeing as though this thread popped back up the other day.
I pulled the 200kw engine down out of my AUII XR8 ute tonight to carry out a freshen up. I got the dial indicator and magnetic stand out and measured the Yella Terra rockers that were fitted to it, and can confirm that they were also 1.7:1 ratio.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
11-08-2012, 12:14 PM | #150 | ||
Agreed Jeff, I've been through all my Crane data, and I cannot find any evidence past or present of Crane making a 1.6:1 ratio pedestal rocker... Only 1.7:1 ratio.
2 users like this post: |
