Old 31-07-2010, 10:37 PM   #1
LaurieS
Default Throttle Position Calibration
Can somebody please tell me how to calibrate the throttle position sensor, I have the manual on cd and all it tells me is how to remove and refit same, it does not tell how to calibrate it. Sorry guys it is on a 2002 au 6 cylinder auto.
LaurieS is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2010, 11:22 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
no calibration required, it's all done by the computer
Old 01-08-2010, 04:37 PM   #3
LaurieS
Thank you for that Mr Hardware, I had been told that I had to recalibrate it every time you disconnected the battery, that is why I came to someone that can put me on the right track.
Old 01-08-2010, 04:40 PM   #4
Kryton
Kryton's Avatar
every time you disconnect the battery, the ECU resets itself.
Thats probably what they meant.
Old 01-08-2010, 06:06 PM   #5
GK
Walking with God
GK's Avatar
Yep, and the reset procedure that speeds the relearning process of the ECU.
Resetting of AU ECU
http://www.fordforums.com.au/showpos...9&postcount=85
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 01-08-2010, 10:12 PM   #6
Mr Hardware
Sorry bloke, I'm readin ya now.
As GK said.
Old 02-08-2010, 02:55 PM   #7
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
small question on resetting ecu. says put car in gear for a manual, i assume the clutch would have to be in, which kinda means the car is in neutral
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2010, 03:37 PM   #8
GK
Walking with God
GK's Avatar
Indeed. I actually got that one from another member, so am not really sure what he meant by that one! LOL!
As long as the few minutes with the aircon off and on are done in a manual, it should go okay.
GK
Now gone!
On LPG
Old 02-08-2010, 04:12 PM   #9
Mr Hardware
i suppose you could put it in gear with the clutch released and just idle roll down the road for two minutes
if it was 3am
Old 02-08-2010, 05:02 PM   #10
ronwest
All Bran = Regular Member
... in Cobar...
Old 02-08-2010, 06:36 PM   #11
LANKY 1
LANKY 1's Avatar
jack the rear wheels off the ground?
V8 dreamteam
1st: 2012, 2021
Old 02-08-2010, 06:40 PM   #12
Jimmyd
Selecting drive is to let the ECU learn idle under load.
Same for turning on AC.
If you have a manual, the only load under idle it needs to learn is the AC.....
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2010, 08:36 PM   #13
GK
Walking with God
GK's Avatar
Thumbs up
James
Indeed. Nicely put.
GK
Now gone!
On LPG
Old 03-08-2010, 11:30 AM   #14
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
When it says to put the car in gear, I've always turned the highbeams on.
Remeber hearing that from someone a while ago.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 11:34 AM   #15
Jimmyd
Reminds me of an old girlfriend in her GT........
