01-07-2007, 08:20 PM | #1 | ||
I have just fitted another alternator onto my AU III, but the car is stalling when i turn the wheel or revving from idle. Any thoughts as to what may be the cause?
01-07-2007, 08:31 PM | #2 | ||
power steering fluid is low, or the pressure switch has had it....do you mean if you rev it it stalls? or it revs on it's own?
01-07-2007, 08:58 PM | #3 | ||
If i rev it, it stalls.
Im not sure what the pressure switch is, is that contained in the power steering fulid unit ? |
01-07-2007, 09:20 PM | #4 | ||
nope, the switch is a round white thing located on the rack, where the high pressure hose from the pump connects to the rack...
If it stalls after you rev it i don't know what could be happening, but usually a faulty pressure switch will cause it to stall/run rough when the wheel is turned.. also if you rev it and hold revs does it stall, or is it only when you release the pedal? |
01-07-2007, 09:43 PM | #5 | ||
Only when i release it does it stall. When i hold the rev its fine.
01-07-2007, 09:53 PM | #6 | ||
ok i guess you disconnected the battery when you did the alternator? have you tried doing the ecu relearn procedure yet?
if not it's here http://www.aufalcon.com/cgi-bin/inde...f=techdocs/ECU give that a go and see what happens then |
02-07-2007, 12:54 PM | #7 | ||
I agree with bodes-sh, when you disconnect the battery the ecu loses all of its operating information and takes a couple of days of different driving conditions to re-learn its settings. This can also be a good time to check the cleanliness of the idle speed control valve. It is an easy job. Just follow GKs thread in this forum somewhere. Be patient and the ecu will come good.
02-07-2007, 12:57 PM | #8 | ||
Heres the thread on the isc valve
http://www.fordforums.com.au/showpos...9&postcount=43 |
02-07-2007, 07:46 PM | #9 | ||
Thanks for the links to the threads and the help guys. Im about to go and give the ECU relearn a go & if that fails, the isc valve a clean.
Just a bit of extra info, it feels as though there as no power steering fluid in the pump & makes the noise as if there wasnt, but it is full. Is this to be expected & would the ECU relearn fix this ??? |
02-07-2007, 09:02 PM | #10 | ||
sounds a bit strange about that, i'd be checking out the pressure switch, that's more than likely the problem with the steering, i don't think they cost much for a new one, and they aren't too hard to put on, it's worth a try and if it fixes it great
02-07-2007, 09:33 PM | #11 | ||
The ECU relearn did nothing to help, the steering problem is a little weird & has me thinking that it may be the pressure switch from what im hearing, although ive no idea where it is located. Can you give me a pointer ?
cheers again. |
02-07-2007, 10:01 PM | #12 | ||
it's the white thing with the blue plug and wire coming out of it
02-07-2007, 10:03 PM | #13 | ||
03-07-2007, 11:33 AM | #14 | |||
The Ancient Warrior
You can check this by removing the drive belt and spinning the pulley and see how freely it moves and whether you can feel anything through the pulley or hear if it makes a noise (but on a lower scale) as you described. |
03-07-2007, 12:35 PM | #15 | ||
may also be an air lock take it from lock to lock and hold it at each extreme 2 to 3 sec repeat 8 to 10 times
03-07-2007, 06:40 PM | #16 | ||
Dont think it is an air lock, i tried the fix for that a few times with no joy, couldnt get the damn power steering switch out, the pump itself sounds as though it is fine although there is a small leak from the connector at the back.
I think ill just bite the bullet with this one & take it to a mechanic, its frustrating me a little too much. Thanks to all who replied, ill re-post a little later with the outcome. |
03-07-2007, 11:20 PM | #17 | ||
If the power steering pump has a small leak at the rear of it you can be certain that this is the reason your alternator failed in the first place. Nearly everyone who is anyone on this site has had this drama with the AU series and I highly recommend you repair this ASAP or you will be up for the cost of another alternator. Repco have a good replacement hose for these and are fairly easy to fit. But do it NOW!!!!
04-07-2007, 08:51 PM | #18 | ||
Good news, Gave the ISC & throttle body a clean & shes good as new.
I had a look at the power steering pump and the O-ring on the hose leading into the pump is definitely degraded. I went down to the local auto store today & they said they would have a replacement O-ring in tomorrow arvo. Is just a new O-ring good enough, or would you still suggest getting a new hose ?? how much do they retail for at repco ?? |
10-07-2010, 02:52 PM | #19 | |||
FORD-LOVER
bf mk2.5 ego xr6 |
10-07-2010, 03:17 PM | #20 | ||
what a thread mine lmao, 3 years old
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
10-07-2010, 08:31 PM | #21 | ||
Fordlover
Answer to your question is: - YES – get it fixed ASAP or you will be looking at a new alternator soon. There are many threads on this issue. If you are handy with tools and an angle grinder / hacksaw, you can buy the hose attachment alone from Ford for a few bucks and fix it yourself. Or replacement hoses are available from Repco or ebay (app $60). Cheers, George |
10-07-2010, 11:21 PM | #22 | |||
FORD-LOVER
bf mk2.5 ego xr6 |
10-07-2010, 11:23 PM | #23 | |||
FORD-LOVER
bf mk2.5 ego xr6 |
23-07-2010, 07:31 PM | #24 | |||
FORD-LOVER
bf mk2.5 ego xr6 |
23-07-2010, 09:04 PM | #25 | ||
The search function is there for a reason
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
23-07-2010, 10:14 PM | #26 | |||
Former BTIKD
24-07-2010, 01:14 AM | #27 | ||
hey guys just reading bout the pressure switch and i unpluged mine as i put cruise control in, the new loom was off a v8 and didnt have a connector for it. havent seem to have any dramas yet. is there any problem with leaving this off?
