Old 18-01-2010, 04:13 PM   #1
SARRAS
Default 98 Festiva - Radio Code proceedure
Got Festiva, Got new Battery, Got Radio Code, NO GOT Handbook! Can anyone help me with the proceedure to enter the radio code on the standard radio? Thx...
SARRAS is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 02:57 AM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Bugger.. I got it written down at home but am on holidays. I got it from Ford direct. Actually they called me. I called a dealership to get the procedure, that didn't work (was wrong procedure) and then got a call from Ford HO a few days later asking for feedback on the customer service I got.
When I explained what happened she assued me that a tech would get back to me, and they did with the correct procedure.
Call a dealership, failing that, call whatever number Ford has for customer help etc.
Old 22-01-2010, 03:33 AM   #3
Pinkbits
Pinkbits's Avatar
It should have the word "code" on the display, punch in your 4 digits and you should be right.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2010, 05:31 AM   #4
Yellow_Festiva
Where to next??
If you have fooled around with it and made a few mistakes you need to reset it (if memory serves) by leaving key on acc for a certain length of time then starting over again...
Then again, that could have been the wrong information I got in the first place..
Old 03-04-2010, 07:58 PM   #5
MKIITurbo
What happened with this mate?
I got a friend who entered hers wrong a few times and now the radio says 'error' on it. Ford want $220 to pull it out and have it re-flashed. Sounds like crap to me. She has since got the correct code from Ford but hasn't been able to enter it. Have tried disconnecting the battery overnight but no go.
I would have thought leaving the car in 'acc' for sometime will drain the battery....Is that right?
MKIITurbo is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2010, 08:41 PM   #6
Yellow_Festiva
Where to next??
Ford want how much to re-flash a 10 year old cassette deck?
There is a wrong way, and a right way to do it. Refer to my post above. The dealer I called for help had the procedure wrong and got me nowhere.
Call Ford direct, I forget the procedure but I didn't need to disconnect the battery etc.
If that fails, replace the tape deck with a new unit... $220 will get you a very nice one I'm sure.
Old 28-04-2010, 09:19 PM   #7
Aarony92
my code worked fine on my 98 festiva, just followed the instructions on the manual
Aarony92 is offline   Reply With Quote Multi-Quote with this Post
