04-09-2005, 07:14 PM | #1 | ||
just wondering if any body could tell me how to make my falcon a little faster? its a 5spd 3.9 CFI. and its on gas. it goes pretty well on high octane pump fuel but still lacks power at the bottom end.
cheers. used: |
04-09-2005, 07:16 PM | #2 | ||
Last warning
its going to be suggested sooner or later.
MPFI conversion, even the LPG will gain power with the extra manifold space.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
04-09-2005, 07:27 PM | #3 | ||
how much would i be lookin at???
04-09-2005, 07:27 PM | #4 | |||
04-09-2005, 07:44 PM | #5 | ||
I guess you were too slow CRUZIN EB!
You could probably get all the parts needed for the conversion second hand for around $200-$300, a mechanic would probably charge a fortun to do it for you and wouldn't know what he's doing anyway. I've got a bare EA MPI manifold you can have for $10. :P |
04-09-2005, 07:47 PM | #6 | |||
04-09-2005, 10:01 PM | #7 | ||
its not a!
If i were you
Mpfi conversion Find a top end off an el xr6 (fairmont) they pull power figures close to the v8s Extractors full system Cam |
05-09-2005, 11:16 AM | #8 | ||
Turbo!!!!
Twin Turbo 5 Speed Fairlane Complete!!! |
05-09-2005, 12:37 PM | #9 | |||
MONTY is Alive !
dump the ea and get a ba turbz
1988 Ford Fairmont EA Series 1 MODS: Hurricane Extractors, Red dash light, Fake Xenon Lights, Mpfi Conversion, Dumpage, 17" ANZ Mayhems (Chrome) TO COME: 5 speed trans, 4.11 LSD, Carputer, Stage 2 cam, Major Head Work . : |
05-09-2005, 12:52 PM | #10 | ||
Former E-Series Member
Since no one else has said it, a short diff ratio will improve your bottom end.
05-09-2005, 01:06 PM | #11 | |||
its not a!
05-09-2005, 01:09 PM | #12 | ||
a mechanic gave me a quote, he says its a big job and it will cost round $1300. i think thats a bit much. but ill keep lookin into it.
05-09-2005, 01:19 PM | #13 | |||
its not a!
That seems a bit high, you could have a cam and exhaust for that! |
05-09-2005, 02:46 PM | #14 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
06-09-2005, 05:13 PM | #15 | ||
im really considering doing the conversion.although not sure if i want to do it myself.i cant find the info outlining how to do it , even after like 5 different searches...if any body has/knows of anyone selling the parts i need can you let mu know.. cheers.
and also a list of parts that i need as i have no idea. cheers.......craig |
06-09-2005, 08:22 PM | #16 | ||
02/90 EA II Fairmont
www.fordtech.com
check a wrecker for parts... get the inlet manifold, including fuel rail, injectors, loom etc... should be ok with CFI dizzy, Get MPFI Fuel Pump and ECU also, and also airbox and piping, unless your planning on running a Pod filter or similar? I had no idea what I was doing and I pulled it off.
211RWKW EA |
09-09-2005, 03:59 PM | #17 | ||
Hey Guys, I'm new here. i've just a couple of questions. Any answers much appreciated. I've got a 89 EA Ghia, with a LSD diff and i can't get it to do a stand still on petrol or gas, in the wet or dry! i've got pacemaker extractors,2 1/2 inch high flow cat,and a bmc air filter and soon to have a 2 1/2 right through. Is there something wrong with my car, or do i just not have enough power? thx all
09-09-2005, 04:10 PM | #18 | ||
Welcome, you will most likely need to start with your diff as the ratio is probably too tall. Also check your throttle cable is not stretched.
09-09-2005, 04:18 PM | #19 | |||
09-09-2005, 06:22 PM | #20 | |||
its not a!
i said 'close'
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
10-09-2005, 01:24 PM | #21 | ||
I Have A Ford WooWho!!!!
Putting the head off an El onto an ea block will probably make it go slower! The EL heads had a much greater dome in them thats why ef el pistons had such a small dish in them. Unless you're going to put acl race pistons (or somthing similar) with a shallow dish in them the el head will do you no good!
10-09-2005, 01:44 PM | #22 | |||
11-09-2005, 07:22 PM | #23 | ||
go for an eb xr6 head, they were alot better than the standard falcon one
