likes falcon's
my car was a ea gl, and now has an ed motor with fairmont cluster, oil pressure shows up at 2 bars, and wen i boot it goes upto 3-4
is that abit low? is it possible that my oil pump is crook?
www.carhubsales.com.au |
oil pump probly
Wherever u go there u r
i doubt pump is buggered when it can still go to 4 bars dood, lol, my ea sits on bout 1 bar at idle and goes to about 3, 3.5 when i nail it,
cheers
Last warning
thin oil?
low idle?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
likes falcon's
penrite 20/50 and ye idle is pretty low 600rpm
likes falcon's
and with my estimate i may be wrong an it could be your figures, prefer to spend more time looking at road than at my gauges lol
hibernating
well I don't know why buy my oil pressure doesn't go above 2 bars. and lowest it goes is 1 bar.. always sits around there. I'm not too worried because it seems fine but maybe the oil pump in my engine is a bit stuffed... wouldn't surprise me because the sump is majorly dented.
likes falcon's
we cant all have bad oil pumps? lol surely!
mine does the same, so i guess we all have bugger pumps...
car that goes (just) <----- gonna be MENACE so :thebirds: |
hibernating
I might get a new oil pump and replace the sump one day... but I can't really be bothered... won't be an easy job
#11 | |||
Bad Music and Litre Bikes
in the LTD my oil pressure warning light and buzzer comes on when im sitting at the lights. But as soon as i take off again its fine. Or if i turn the car off and then straight back on it coms back to normal, just above half.
I have heard that the sensors in the engines sometimes go a little "bung" but its nothing to worry about if it goes straight back up when your driving ![]()
XY Wagon - NAKED! Quote:
#12 | ||
![]() Join Date: Aug 2005
To allay your fears of low oil pressure Niko, why not have the oil pressure tested? Guages are fine but as they are an electrical item can be slightly out.
Do you use a Genuine Oil Filter when you do the change? Some filters are CHEAP rubbish and some have no non return valves. The oil sounds ok and I seriously doubt that the idle speed has much to do with it. Early EA's did have Oil Pump trouble but I doubt that is REALLY your problem. |
#13 | ||||
#14 | ||
likes falcon's
ye cool, and its an ed 4litre i have in it, i never really took notice or cared in my ea ghia, as they never had it on the clusters :P
#15 | ||
3-4 bars is a pretty good reading....don't worry about it.
#16 | ||
Are you getting a horrible noise from the bottom end? No? She'll be right
![]() (Maybe I should stop sticking to that ideology!) |
#17 | ||
likes falcon's
ye i know wat ya mean, ive never had oil guage bfor, and no noises from motor except for wen it sits for abit i get tappet noises or watever they are but goes away quikly and thats why i thought i might ask
#18 | ||
Undergraduate EB Operator
well im not sure if this is right or not but mine sits on about 3/4 98% of the time except if im sitting at the lights then it flickers up a bit (sometimes into the red) but i haven't had any problems with it. my guess is the sender is acting up, anyways u guys' oil pressures seem low, what grade oil do you run? im using 20W50 atm because of the recent gasket problems
Simon ----------------------- 04 BA Xr6 ... now with carpark dints ![]() ----------------------- |
#19 | ||
Posts: n/a
Try penrite 10/60 sinthetic, gives great oil pressure in my ea
#20 | ||
high oil pressures what u need to worry bout
means its getting low |
