Next upgraded Mk1 Leopard
Bug@er... Two back fires in two days. Both after going down a hill off throttle then, accelerate,... then BANG. Pics on the weekend. Need a new section just after the concertina section. Ripped right thought the plastic.
UK ![]()
God Bless LPG
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
Petro-sexual
Assuming this is a mixer ring system...
Check your spark leads, dizzy cap and rotor button. Also check the converter balance line. Common cause for this is weak spark. When on cruise/decel the mixture is lean, then when you accelerate the mixer takes a little time to respond with enough lpg creating a very lean mix, which burns very slowly (and is further exaggerated by weak spark), slow enough that next time the intake valve opens for a fresh charge it is still burning, this ignites the new stuff coming in and everything back to the mixer resulting in a nice big bang. If you havent already, invest in some spring clips for the air box too. |
Lost Boost Gained Class
ahh i get the atleast 2 times a week Fix is simple drive it on 91 or something better
2006 BF Fairmont Ghia
2001 AU Falcon |
#5 | |||
and I have spring clips on the airbox lid. UK
Pics
![]() and ![]() Bang Uk
#7 | |||
Walking with God
Worth a go I'd reckon for sure. I have a section of that pipe you're after. You can have it for nicks if you like. GK
#8 | |||
u can buy a rubber valve that u can fit into the airbox that will open if u have a backfire so it wont happen again, but i would have it retuned also.
ive even seen a few taxi's with rubber bath plugs pushed into a hole in the airbox with a chain to catch it if it blows out ![]() ![]() |
Cruising...
Two backfires in two days?
I saw this bloke who backfired his au fairlane 3 times within 15 seconds :P Anyway that musta been a pretty big bang to stuff it like it did with springs |
If only GK lived in Sydney... off to pick and pay less to look for parts..
interesting flap set up elf UK
#12 | |||
#13 | ||
Rusticating
Is that a local product? I'm aware of the british one , but would rather buy a local one.
Territory SYII RWD, BFII RTV tray |
#14 | ||
im not sure where that one originated , it came on my ef ex-taxi
i have had the one u pictured too and fitted that to a mates courier ute, lpg/petrol that had blown up 3 airboxes at $198ea, and none since u could always make your own too, its just a hinged flap with a bit of rubber behind it. when the engine is running the flap is getting sucked shut are the sprintgas systems u are running made wholly in australia? why not ask them if they do one |
#15 | ||
i agree with GK, sounds like the tuner made the mixture too lean. the balance line is supposed to help the converter richen up under high vacuum conditions, ie high engine speed with little or no throttle because the engine tries to suck the converter diaphragm in leaning out the mixture. if this has been removed, blocked or moved for some reason it will affect it in the way you have found. did the car feel like it was shuddering just before the backfires? it will feel pretty rough if the motor is too lean.
#16 | |||
Walking with God
GK
#17 | ||
Thanks for the offer GK. If I blow up another one I'll take you up.
Got on today for $10. Question is do I use it? I am thinking of taping the blown one up and using it until I get he tune sorted or a flap spring installed. What do you think guys> UK
#18 | |||
Walking with God
Cheers, GK
#19 | ||
Found an old stubby holder and cut to fit. Hope this holds until I get the car tunned.
Hole... ![]() and the car ![]() and ![]() Now to take it for a test run UK
#20 | |||
Walking with God
Awesome bush mechanical work there UK! LOL!
How did the test run go? GK Quote:
#21 | ||
Just call me Les Hiddins ...LOL
Drove it Sunday night and to work today. No BANGS so far, car just driving like 'normal' today. I kind of like the cover, looks like a footy injury from playing 1st grade.... UK
#22 | |||
Walking with God
GK
#24 | |||
Got any pics of your 4 holes??? Uk
#26 | ||
Ok so on the same axis. Why 4 holes and why that size?
Uk
#27 | ||
Petro-sexual
There is a lot of expanding gases that need to get out in a backfire.
I dont know if they were exactly 30mm but from memory about that size. |
#28 | ||
Are the Supercars on yet?
My ute used to backfire every now and then, not to that exent though, it hasn't done it for half a year since i got my zorst system put on! weird
![]() ![]() V8 dreamteam 1st: 2012, 2021 ![]() 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
#29 | ||
Got these today, going back to see Joe at Cresent on Tuesday afternoon, I'll see how these go
UK ![]()
