i have an ea falcon with 6" splits in the doors but when enough bass goes through them they are hitting the door trim. does anyone know how to get them spaced out so that they do not hit the trim anymore. thanx guys
just make a thin (say 3-6mm) MDF ring that has a slightly larger inside diameter than the rubber surround on the speaker. Sit it over the speaker - maybe hold it in place with some blu-tac and put the trim back over the top. It should push it out enough to stop them hitting.
thanx ill give it a go
Lovin the Manual.
how are you fitting 6"ers into the ea doors?
its not a!
sphell saves the day!
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
i cut the doors with metal cutters and screwed the 6" intot he doors, it was easy as pie
The one and only
In cutting the door usually makes it weaker.
Also, how much bass are you puting into the 6.5?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
i listen to a lot of bassy songs but the speakers arent at their max
#9 | |||
Shoot.
20V Turbo |
meow
When mine get enough bass going thru them the door rattles :(
i find that to :(
#12 | ||
Posts: n/a
use the that foam thingy or buy that sticky tape seal
#13 | ||
Hmmmmm
i used that stuff u put around the edges of your house doors to stop the wind getting through, did the job 4 me
#14 | ||
Posts: n/a
why dont you just opt for a single 10" sub to handle your bass and relieve the stress of your 6" speakers of taking on so much bass, plus you'll get a much clearer bass note from the sub as it can hit much lower frequencies than ur speaker can and you'll lengthen the lifetime of ur speakers
if you dont want a sub in the boot go get yourself a 8" free-air sub and mount it on the back parcel shelf make sure to use a spacer made out of MDF to get the realli tight bass notes |
#15 | |||
Shoot.
20V Turbo |
#16 | ||
yes yes i do (luke)
