Lovin the Manual.
hey guys...
when my car has been sitting for an hour or so or more... it will crank for ages before it fires.. like an old ty car on gas (well i guess it is an old ty car.. BUT NO GAS) anyway... when the car is warm it starts easier but still will crank more than it should before it fires.. once the car is running it is smooth however after 3000rpm or so the power seems to die off.. like if i dyno's it my peak ov the power curve would b at 3000rpm then just stay constant... the car will rev out to 5000 no probs but just doesnt have as much pull as it should any ideas? oh.. i have changed fuel pressure regulator.... and fuel pump to no avail... thanks |
Low and Loud
injectors? what are they like austin?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
maby the starter motor?
#4 | |||||
AFF's 1st DM.......
#5 | |||
AFF's 1st DM.......
Got a spare tfi module handy
but thats what happend with mine?
hibernating
checked the ignition timing?
windsor user
plugs and leads....
? mine was dying off after 3000 / 3500, and its been a while since i changed em, so i figured it couldnt hurt to do. revs out smoothly now with no flatspotting... might be worth you checking |
#9 | ||||
AFF's 1st DM.......
#10 | |||
The one and only
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
GDAY THERE
If you are confident pull the dizzy out and check for play in the shaft sounds alot like what happenned to my old man this week and yes he is an agrade mechanic with 40 yrs experience and he found that the shaft was worn (in a 89 ea fairmont ) and had rubbed against the wire inside the dizzy once replaced starts fine every time now hope this helps
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
Lovin the Manual.
hmm...
ta 4 replies i got new plugs last week... ill check timing ... mmm dont hav a spare tfi to try and the shaft play...mm.... well ill check timing 1st.. |
#13 | ||
Lovin the Manual.
oh and injectors?
im not sure,, i guess theyre pretty old is there an easy way to check their condition? |
#14 | |||
The one and only
I did my ex-GF's at 70,000 so it would keep effiecient. If you have done over 150,000 and you doubt they have been done, take them out and get them reco'd.
