Wherever u go there u r
I have a 89 ea fairmont and im about to convert to manual, then a month or so after that i will have finished my 4litre for it, does the 4 litre engine accept the 3.9 manual flywheel and clutch?
thanks
Kaddis Customs
im pretty sure i read somewhere that they dont line up....i might be wrong tho
FG XR6 E-Gas Ute in Ego |
3.9 Flywheel and clutch will fit on 4.0L crank.
I would go a 4.0L flywheel and clutch though since it is a fair bit stronger.
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
but the t5 box physically bolts to 3.9 and 4.0 blocks?
Yes it does... only complication is when AU Engines are involved.
I just put a t5 box into my 4L eb i used the 3.9 flywheel and clutch had to problems at all.
cheers scott
'93' EB fairmont 5 speed manual. extractors, high flow cat, 2.5 inch sports exhaust. Freshly painted in Cobalt Blue. lowered with ultra lows. 17 inch mags fitted. Just finished putting a low km el motor in her |
thanks lads,
cheers
AKA ___DOMMUZ
i put a 4.0 in my ea but it had the fly wheel and reco gihabox but i think it should go on ok you can only try i had to change the intire loom and chip
