Old 16-01-2010, 07:31 PM   #1
ads266
Default 2006 WQ running rough.
I have a 2006 WQ LX. Recently it feels like i have had dirty fuel going through the car. It loses power then picks up again. Travelling in 4th gear it feels like its chugging along, slightly jerking back and forward. I have had new leads and plugs put in also. I am thinking it may be the throttle body from my own investigation. Does anyone have any other ideas as to what it may be? Thanks.
ads266 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 08:16 PM   #2
robjh80
robjh80's Avatar
Yea ... possibly the Throttle Body or MAP sensor
Make sure the Air and Fuel filter are OK .. could also be an electrical issue.
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 08:26 PM   #3
ads266
Thanks for reoplying so quickly mate, its much appreciated.
Old 16-01-2010, 09:34 PM   #4
fiestaz
fiestaz's Avatar
sounds weird how many km's on it?
Old 16-01-2010, 09:50 PM   #5
dannyhilton
dannyhilton's Avatar
My WP Zetec had a similar experience. One day it was fine, then over the next week it became sluggish, rough and the whole car was shaky from the engine vibrations. My mate serviced it and she was fine, as good as new. Not sure if this helps but if you haven't had a service in a while it could be experiencing what mine did man?
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum
PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec
dannyhilton is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 09:53 PM   #6
ads266
I have done just over 60,000 km's. Apart from this fault i have had nothing go wrong with her. It so frustrating. The engine light has just come on which from the book seems to imply that there is a software fault or its a diagnostic fault code. To all who replied thanks for trying to help.
Old 16-01-2010, 09:56 PM   #7
fiestaz
fiestaz's Avatar
yeh take it to a mechanic, could only need something simple... hopefully
Old 16-01-2010, 09:58 PM   #8
fiestars
first post had the same problem with my 07 fiesta ford said it was the oxygen sensor what ever that is, anyway the replaced it under warranty n the problem went away
fiestars is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 10:44 PM   #9
dannyhilton
The motor in the WP/WQ is a top little unit, mine had 99,000 on it when I sold with only minor issues that were fixed after servicing etc. Fingers crossed it's nothing serious man.
Old 16-01-2010, 10:52 PM   #10
fiestaz
fiestaz's Avatar
mine did 100,000 yesterday, absolutely brilliant.... never skips a beat,, except when i stalled it once :s and it was a bit reluctant to start again.. but otherwise it is a top unit
Old 16-01-2010, 11:19 PM   #11
Fez WQ
Default I had this happen
I had this happen its was a cracked spark plug (ford) Dealer said that it had been dropped
It will not be much and yes my engine light was comming on the same as yours, may even be a plug lead ...
I just bought a WS Fez and its is great LX in vison
Fez WQ is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2010, 11:25 AM   #12
InnerDevil
Owner Of The Evil ST
InnerDevil's Avatar
Hey guys im havin this problem aswell, this first happened like 7,500km ago after my first service since buyin my 04 WP LX, and my mechanic just pulled all the spark leads out and put them all back in and..... walla it worked ......
Just today driving back from gettin breakfast it started doin the same thing, so i just pulled the leads out but the problem aint goin away and the engine lights comin on aswell. The motor is really really sluggish and makin a fluttering noise aswell
can anybody help, thanks
EDIT:
(and its no longer under warranty so i cant take it back to the dealer)
"InnerDevil"
"Evil ST"
2004 WP Fiesta LX 3Dr
Panther Black
17" Lenso Type M ~ Wrapped w/ Falken Tyres
Pedders Sports Ryder Lowered Springs
St Rear Spoiler
InnerDevil is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2010, 08:54 PM   #13
Twellsy
I have had this problem in the past ( Nissan Pulsar SSS and Excel ) after putting aftermarket leads on , try putting the old one's back on or if they are no good get replacement one's from Ford. Also good idea as mentioned earlier by other members check or replace the spark plugs
Twellsy is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2010, 09:51 PM   #14
Cyborg1978
The best thing you can do is take it to a ford dealer. They can put it on there computer and get the correct fault code. Think if it's something like a carnk sensor, and you don't fix it ASAP you may be looking at a rebuild if you let it go for to long. Bite the bullet and get ford to have a look.
Cyborg1978 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 09:03 AM   #15
luvpsi
sounds like the ignition coil may be cracked too..
luvpsi is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 09:58 AM   #16
InnerDevil
InnerDevil's Avatar
Had my mechanic had a look at my WP for a solution to the problem of my sluggish engine, he looked at the spark plugs, leads, coil, and still no fix
Also what he did was pull out spark plugs one by one, cylinders 1,2&3 made a considerable change to the running of the engine.......
But cylinder 4 (far right) didn't.....
So is somethin wrong with cylinder 4......yeah
He also tried checking the compression of the cylinders but didn't have the right sized connection
I tried changing the sparks plugs, that didnt work,
Can anybody please help, this car is undrivable any its my only car
"InnerDevil"
"Evil ST"
Panther Black
St Rear Spoiler
Old 20-01-2010, 10:43 AM   #17
ads266
The engine light is off and the car is running fine again. I am sure it will play up again and Ford couldn't find a problem with it. They (Ford) stated i need to get it to them when it is running rough but thats hard to do when its after hours. I will update this thread again if i have any more information. Thanks for all the responses too its been appreciated.
Old 24-01-2010, 08:13 PM   #18
InnerDevil
InnerDevil's Avatar
Got my WP Fiesta back today, ended up bein a coil pack and spark leads problem.....
Don't know what caused it but all i gotta say is THANK GOD my gf dads a mechanic cause he said it wasn't cheap and did the whole thing for free.......so i can't give u guys a price for those parts or the installation fees
Thanks guys for all the tips, help and info
"InnerDevil"
"Evil ST"
Panther Black
St Rear Spoiler
