Old 15-01-2010, 04:22 PM   #1
shepv8
V8's for ever
Default Spark Plugs
Gday all,
I am after some info on changing the 06 LX focus spark plugs. I have a set of NGK laser iridiums - ITR6F13.
I havent even popped the hood yet to check this out but from memory you take off the big plastic cover and then you have simple access to the plugs. Does anyone know the torque setting for the plug into the head? I will be using anti sieze on the threads . Has any body got any tips or bad experiences that may help with the job... Im thinking its pretty straightforward. I will also be changing the airfilter and while Im at it Ill pull the MAF sensor out and clean that as well.
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2010, 05:58 PM   #2
mrbaxr6t
mrbaxr6t's Avatar
all I can say is be sure not to cross thread the plugs in the head will screw it up - that said tho I have never done plugs in a focus and as for torque settings I have always nipped them up by hand then give them a 3/4 turn with a ratchet to crush the washer thing on the plug - never had any problems doing it this way thus far - but I have not done this on a focus these are general guidelines ;)
you most likely know this... but somebody may not
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 01:45 PM   #3
Imolator
Quad Cam
Imolator's Avatar
The spark plugs in the Focus dont use a gasket, they have a conical seat.
They should be torqued down to 12Nm, if you dont have access to a torque wrench then about 1/4 of a turn will do. And as shepv8 said watch out for cross threading.
Imolator is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 11:50 PM   #4
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Thanks to DZFord, try this:
http://forums.focaljet.com/duratec-t...ark-plugs.html
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2010, 08:59 AM   #5
shepv8
V8's for ever
Originally Posted by #Russ#Es#
Thanks for that link. Its a good guide for people, and I may end up getting some grease for the plug boots. Weve got some soray at work which I wish I brought home now that will do perfectly.
