Shoot.
I changed my brake pads the other day (thanks EFFalcon & Karl for the tips). I'm using the new Bendix CT pads on my front slotted rotors - you don't even need to bed these pads in
![]() Anyway, how do you get the front rotors off? The backs are as simple as one phillips head screw.. And what's the deal with bearings? Are they hard to replace - are special tools need etc?? Cheers
20V Turbo |
#2 | |||
IIRC - take the center cap off, remove the split pins and crown nut and the rotor pretty much falls out.
Smash the Boost
nah dude, once you take the dust cover off the hub, take out the split pin, undo the retaining nut and pull the bearing out, you will see how it all works. Its a piece of **** really. Just make sure the races go in properly on the new disks and you pack the bearings with grease properly.
Funny how u said the rears were easy, i couldnt get those screws out on my car.
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
RIP...
The most important thing to do is pack the bearing properly with grease, and applying the correct pre-load to the bearing (very important).
Rick.
. Oval Everywhere... |
Once shy... twice bitten
Exactly what Sox has said, packing the bearings properly with grease is crucial. If your still unsure I'll take a scan of the Gregory's manual and send them to ya tonight. PM me with your email address if you're interested.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. |
Lovin the Manual.
on the rears i bought a huge screwdriver for like 15bux and it gets them ty scews out that always get stuck!! muhahahah
Smash the Boost
I had to use a impact driver and a few bits before mine decided to play the game
Fairmont6
undo the to callip-er retaining bolts i think ones a 12 and ones a 13 depending on model. remove caliper and pads and push pistons back. pull off the beariong cap, nok out the split pin and unto the castle nut. pull the rotor off make sure u hold the bearing so it does fall out. once removed it will expose the rear bearing wich just slide off. clean all the components well, make sure the old grease is removed from the bearing, soaking in good ol petrol works well
#9 | |||
![]() Join Date: Dec 2004
It's a pretty easy job. I found Timmeh's guide really helpful.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
Shoot.
Cheers guys, it sounds pretty straightforward. I might do it the next time the pads need changing.. I have used my current ones for only a couple of hundred kms, so if I was to go and get the discs machined, wouldn't I have to get new pads??
Does anyone know how much the rear calliper tool goes for (not a universal one)?
20V Turbo |
