*Smart *** comment here*
just a quick question, i read in another post, that when mounting a pod filter in replacement for the exisiting air filter it is ideal to keep the filter in the exisiting air box as to avoid sucking in hot air and defeating the entire purpose of having the pod filter... this i understand
my question is, does this mean to simply remove the airbox cover, bolt the pod on (so to speak) so that it sits in the existing airbox, with the traditional air intake doing its thing, and not replace the airbox cover. OR does it mean to place the pod inside the airbox and place the cover back over the pod, so that it is entierly contained within the airbox, in otherwords, if the bonnet is open you would not actually be able to tell the pod was installed. considering i am looking at purchasing a pod very soon i'd really appreciate any input and problems other people have come accross, noteably those that have el's. |
Ich bin ein auslander
best is to modify the airbox to mount the pod enclosed with lid. That way you get the best protection form the heat and still get the improved flow of the pod. There have been a few threads showing how this was done to other member cars, just do a search for pod filters and you should find them
Growing old is compulsory, growing up is optional! |
Yes you need to modify the lid to fit back on otherwise you will be sucking in hot air. Far easier and just as good to use a good quality panel filter instead though.
#4 | |||
but on a serious note, for some unknown reason i really do have my heart set on a pod filter and i dont mind doing the mods to the airbox either... is there any particulars that really need to be taken into account when it comes to pod filters, or are they all much of a muchness? |
#5 | |||
As for the **** factor of a pod, it's inside an airbox so you won't ever see it. It's just a lot of trouble for no gain IMO, but if you don't mind the work then go for it. |
Here's mine, in a BA airbox, but would easily fit an EF airbox. Mod only took @1hr using an EF (cutdown) air intake I had laying around, but as can be seen, is easily to revert back to original, but with the noticable results (on LPG) it'll be staying, will upgrade to a better brand now it's a proven enhancement as this pod is.......entry level.......no point spending heaps till I knew it worked. :eclipsee_
Removed by laminge |
By the looks of it, if you calculate the filter area of that pod my bet is that it would be less than a panel filter therefore will also flow less. This is the problem with fitting a pod in the factory box, there isn't that much room. You really need to do a custom airbox, but you need a lot of power tao make it worthwhile.
#8 | |||
#9 | |||
Fairmont6
i think ull find k&n also make a costom airbox and custom pipng to suit most vehicles i plane on having my pod ontop of my engine underneath the "soon to be" gt bonnet scoop
