I had a look under my bonnet checking out my car and noticed when i looked under the car coolant droplets had formed on the bottom of the engine area on futher inspection it looks as though coolant is leaking from the middle section are theyre any gaskets located around there that may be the cause of the issue, no coolant is hitting the floor but its definately leaking, any ideas on whats causing this issue?
many thanks Shawn |
at a guess, Water pump. They have a gasket, but it's possible that it's the pump itself. Just get some silicon onto it.
i looked at the welsch plug at the side of the motor and its leaking from it
any idea on how to replace one of those? water pump seemed ok and yeah thanks for your help... |
