View Poll Results: What should i do | |||
No wing, just a lower kit |
31 | 63.27% |
Leave the normal wing on it |
4 | 8.16% |
Get a tickford wing |
14 | 28.57% |
Voters: 49. You may not vote on this poll |
Kaddis Customs
i have a tickford kit(minus the wing) sitting in the garage about to get painted and put on but im deciding wether to leave the normal wing thats on it, get a tickford wing or just have a lower kit without any wing
i also have to get my boot has been resprayed because before i got it, it was done in a diferent shade of red so i have to get that boot resprayed anyways thanks!
FG XR6 E-Gas Ute in Ego |
Low and Loud
Go the Tickford wing ;) It looks wierd with no wing and the factory kit.
But its up to you ;)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() Last edited by InitialD; 21-08-2005 at 06:53 PM. |
White Lightning
yeh go the ticky gear. its great.
Get the Tickford wing, it will make it look compleat,
Post some pics when done mate ![]() |
#5 | |||
![]() Join Date: Dec 2004
Put the kit on without any wing. It will look great, trust me ;)
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
Two > One
Wings are bad mkay
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
Driftin shopping trolleys
go the tickford wing mate the kit looks good with the tickford wing.
Tickford kit. No wing ;)
And dumpage :P |
#9 | |||
my other ride is the bus.
Yeah go the Tickford wing and drop it on its ****.
1994 ED Fairmont Ghia (Retired to the shed...) 1999 AU Futura + Lots of Land Rovers Quote:
Shoot.
Is it an EF or EL kit? The full EL kit with the F2(?) wing is hot.
20V Turbo |
no spoiler, it spoils it.lol.
dont like wings,although my car has one. the ticky wing isn't to big on ef/el's so it looks pretty good with the kit. personaly, no wing... |
#12 | ||
I'm with the later posts, no spoiler.
5 Speed EL Futura 140rwkw last dyno |
#13 | ||
GT
mate get the ELGT WING it will look great with the tickford bodykit . just do it.i drink kilkenny draught . after you do it you can send me a carton for the advice . i'll look forward to your PM once fitted.
#14 | ||
GOT 20'Z?
ef el has to have wing with body kit get the biggest xr one it will look sik and drop it on its ****.
one day my car will live upto its plates! ![]() |
#15 | ||
There seems to be many varying opionions here. But it all comes down to what you want really. If it were me I would go with the wing, meh, but thats just me. Perhaps you could get one of the other members to photoshop a wing on it to see if u like it?
#16 | ||
GT4.
I'd Say no wing. Its different thats all, and most xrs have one anyway.
#17 | ||
Kaddis Customs
yeh i think im going to go with no wing.
i put the side skirts it on and without it being painted it matches up pretty good! ![]() i cant put the front on caus needs to be painted ![]() the anoying this is i went to put the rear skirt on and the stupid part of the tongue for the tow bar that sticks out is welded to the tow pack! so i cant put it on unless i cut a chunk out of the back which im not! ![]() thanks for all the input!
FG XR6 E-Gas Ute in Ego Last edited by Kaddis; 23-08-2005 at 06:20 PM. |
#18 | ||
Last warning
so its either cut hole in rear bodykit, or remove tow bar?
whats gunn happen ;)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#19 | ||
Kaddis Customs
no way in hell im cutting out a hole in my bodykit so im going to have to take off my rear bumper and angle grind that tow piece off.
how do i go about taking my rear bumper off?
#20 | ||
Last warning
under the boot carpet near the sides there are 2 grommets (on each side), behind them are a bolt each.
then in the wheel arch, undo the mud flaps (if attached) then there is a bracket in the top corner of the rear bumper, its just a 10mm bolt. under the car there is a steel plate that is riveted to the spare wheel well, i simply cut it off. thats all i think, the whole thing should slide off the back of the car if you're essentially making the tow bar useless, you might aswell remove it all together. lighten the car up ![]()
#21 | ||
Kaddis Customs
cool so i can just unbolt the whole tow pack?
#22 | ||
Last warning
yeah, there will be a way to do it.
its not a very 'big' tow pack, so it shouldn't go much further then just inside the boot. some of the bigger ones go all the way back to near the diff :P
#23 | ||
Kaddis Customs
yeh there was a few bolts in my boot i undid but the tow bar connects to some bigger steel thats i think goes around to near the diff!
ooh well i'll go out tonight and see if i can get it off! my diff also packed in today so i have to rebuild the other on with the LSD and get it fitted ASAP!
#24 | ||
likes falcon's
u can get 2peice rear skirts that have space for towbar
www.carhubsales.com.au |
#25 | ||
GT4.
Yeah, they got a little like piece that comes off for when you want to put in the tow bar. The factory ones did anyways.
#26 | ||
i have got the 2 piece rear skirt on my xr. doesn't look to bad. if your not going to tow again then take the tow bar off, but then you might want to tow something later down the track and you'll have now tow bar and you'll be spewin.
