Old 22-08-2005, 05:00 PM   #1
CruizinEB
Default EB Base cluster - Sports Cluster???
How much would it cost to change the cluster from the base one to the sports one???
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 05:01 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
depends how much you can buy a sports one for ($50 -$100), and all you really have to do is change the oil pressure sender to a output one (about $50 i think), maybe add a few wires.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 05:05 PM   #3
CruizinEB
that easy?
Old 22-08-2005, 05:08 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
To the best of knowledge, someone will confirm 100% the details, try do a search in the word 'cluster' in e-series chat to learn more.
Old 22-08-2005, 06:48 PM   #5
Papa Smurf
Papa Smurf's Avatar
As dellboy says, oil pressure sender and a wire for the Tachometer. There isnt one from standard. I think there is already a place in the connector under the bonnet on the passengers side for it? runs to the coil.
I am about to add one of these myself. Juat make sure the cluster is out of a late enough vehicle to match yours?
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 06:57 PM   #6
CruizinEB
ok great, thanks mate
Old 23-08-2005, 12:03 AM   #7
5speedeb
now with 3.73 lsd
i think eb onwards got the tacho wire as part of the factory loom
anyway check to see if u got i think a pink/ blue wire behind the dash
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 01:30 AM   #8
Inferno
Mr Forty Seven
Inferno's Avatar
Yeah I've got an EBII, all I did was install the cluster and had the mechanic install the oil sender unit and it worked fine, you'll find without the oil sender unit the oil gauge will report either empty or full, cos on the standard cluster the light is either on or off, like a binary switch. It's a very nice upgrade and if I can do it I'm sure you can too
EFII Fairmont Ghia
Fully Optioned In White
XR Kit, Engine & Springs. Leather & Sunroof
Also Featuring
NFERNO Registration Plates
ELXR Front Bar & Bonnet with Sequential Scoop
18x8 Graphite Rims, Genie Extractors and Exhaust, Chrome Moulds
ELGT Steering Wheel, Clear Repeators, Cornering Lamps, Tinted Windows
Walnut Highlights, Pionner DEH-P9650MP Headunit & Pro-Series Speakers
Local Playground: Brisbane CBD and surrounding suburbs
Inferno is offline   Reply With Quote Multi-Quote with this Post
