20-08-2009, 12:14 PM | #91 | ||||
Cane Farmer
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
20-08-2009, 12:58 PM | #92 | |||
Phantom, T56, leather and sunroof BAmk1 :yeees: Holden special vehicles - for special people |
20-08-2009, 01:04 PM | #93 | |||
20-08-2009, 01:11 PM | #94 | ||
Knowledge is Power. If you know what's wrong with the car, you'll know how to fix it, or at least know if the mechanic is feeding you fairy tales.
20-08-2009, 02:04 PM | #95 | ||
Are the Supercars on yet?
you don't need to carry every tool you have with in the car. because you are not gonna do a engine transplant on the way to work/side of the road.
If ur really nice u can carry all your tools and rescue the holdens that have broken down on the side of the road
A Ford win is a good win! V8 dreamteam 1st: 2012, 2021 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
20-08-2009, 02:09 PM | #96 | ||
Tribal Elder
Dont lend out your tools, or your missus. They wll always come back rooted.
20-08-2009, 02:15 PM | #97 | |||
Performance Inc.
If your not sure you can do the job dont start it pay a pro. I dont know many mechanics that like to repair other peoples shotcomings some will do it but it will cost you more.
In The Garage... FPV Super Pursuit Build no 0080/91 Lotus Exige S/C S240 Kart Hasse Chassis 100J Power Quote:
20-08-2009, 02:25 PM | #98 | ||
I always wear disposable rubber gloves when working on the car (buy from Coles in a 100 pack) - no hand washing is great.
Also spend a little extra $$$ on quality tools. A socket is not a socket and not all screwdrivers are born equal. It makes everything SO much easier and you will get your money back in the long run from not breaking parts or tools.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
20-08-2009, 02:37 PM | #99 | ||
The best way to remove the spigot bush out of the back of your crank.
Step 1. fill the space behind the bush and inside bush with grease Step 2. Find a drift that is close the same size as the hole in the bush. step 3. place drift into the start of the bush. step 4 . use a hamer and give the drift one good hard hit. keep filling and hitting till bush pops out. should only take 2- 3 hits at the most. PS Do not try this on the Newer style Chev engines. There cranks are hollow and only have a plug on the inside of the crank that will drop into sump using this method. |
20-08-2009, 02:55 PM | #101 | ||
Never buy the First Model of anything.
08 FG Sedan 04 Mazda SP23 Sedan |
20-08-2009, 03:25 PM | #102 | ||||
AFF's 1st DM.......
20-08-2009, 04:35 PM | #103 | ||
Car modification guide
-cheap -reliable -fast you may only pick 2 options |
20-08-2009, 04:43 PM | #104 | |||
Formula F6 - Hmmmm!
[FONT=Impact]F6 Typhoon R Spec Lightning Strike F6 Owners Club of Australia Force Fed Fords Serviced by Pit Lane Performance '02 Explorer - V6 - Mineral Grey One Day! '69 RoadRunner or '71 Plymouth Cuda or '66 Pontiac GTO Too much horsepower is just about enough." - Carroll Shelby
20-08-2009, 05:27 PM | #105 | |||
20-08-2009, 05:41 PM | #106 | ||||
AFF's 1st DM.......
20-08-2009, 06:13 PM | #107 | |||
Have to say that you'll only do it once. I know I did! |
20-08-2009, 07:29 PM | #108 | |||
BF MKII XR6
20-08-2009, 07:51 PM | #109 | ||
keep a spare key in your wallet
Daily drive 2010 Mitsubishi triton single cab turbo diesel 1968 XT Falcon (project yet to be started) |
20-08-2009, 09:49 PM | #110 | ||
FPV F6X
make sure you when you change oil filters that the old o-ring comes off with it
FPV F6X BUILD NUMBER 189
20-08-2009, 09:53 PM | #111 | ||
Odd nut & bolt bucket....
20-08-2009, 10:01 PM | #112 | ||
blue oval addict
buy a ford.
21-08-2009, 08:53 AM | #113 | ||
If you have problems from a mechanic or Dealer, don't just whine about it in Forums, DO SOMETHING ABOUT IT. Write to the Dealer or Workshop (putting it in writing means that they can't say you never said anything). IF that fails go to CONSUMER AFFAIRS.
ALWAYS keep receipts in a safe place keep copies of letters received and sent. |
21-08-2009, 09:02 AM | #114 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
If your wheel hubs and brake callipers aren’t painted give them a quick coat of pot belly stove black paint.
It’s cheap, can stand hot temperatures and even the worst paint job looks way better than corroded metal. Don’t worry about painting over the rotors. Once the paint has dried this will be wiped clean by the pads. |
21-08-2009, 09:09 AM | #115 | ||
Master Tech
Have you locked your keys in the car?
Does your car have remote keyless entry? This may come in handy someday. Good reason to own a cell phone: If you lock your keys in the car and the spare keys are at home, call someone at home on their mobile phone from your cell phone. Hold your cell phone about a foot from your car door and have the person at your home press the unlock button, holding it near the mobile phone on their end. Your car will unlock. Saves someone from having to drive your keys to you. Distance is no object. You could be hundreds of miles away, and if you can reach someone who has the other 'remote' for your car, you can unlock the doors (or the trunk). |
21-08-2009, 09:15 AM | #116 | |||
Chasing a FORD project!
That, imagine, is incredible. How on earth did you work that out??
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
21-08-2009, 09:28 AM | #117 | ||
Master Tech
Hey NJXR6,
Working in the trade has its benefits lol.... but the only issue is you generally can't lock your car with central locking and have the keys still inside it with the later model spec vehicles... but i believe the earlier cars you can!... |
21-08-2009, 10:57 AM | #118 | ||
Secret Sleuth
lol that myth was busted
BF Mk2.5 XR6 Turbo |
21-08-2009, 11:21 AM | #119 | ||
Capri GT/TS50/GTR
if you cant fix it with duct tape or wd40 its electrical... better get a bigger hammer then
when pulling an engine make sure your roof is high enough to get it out |
