*SILVER SERVICE PILOT*
![]() ![]() Join Date: Jul 2006
Hey all, had to change the drivers side headlight bulb last night so had to remove/replace the battery so I could get to the thing (big hands).
Anywhooo, when driving it today, when you put it into reverse or drive, the idle speed drops right down to almost stall speed and then picks up again. The car has been driven about 40 kms since the battery was out but it still has the low idle after changing gears. I've done the disconnect battery thing heaps of times in different Falcons (AU, BA's etc.) with no problems like this afterwards ![]() Thanks in advance...Linz.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
T3 TE50 Blueprint
Pretty normal, give it a few days for the ecu to re-learn. Or to speed the process up a bit, let it sit there idling in park for about 10mins, the idle should improve as time passes, as the ecu is relearning. Then put it in drive with your foot on the brake and sit there for 10mins again. This works for me, see if it works for you.
gone fishing
or you could try this to "re learn the ecu" it's quicker
http://www.aufalcon.com/cgi-bin/inde...f=techdocs/ECU
Cheers Whiskers |
might be worth cleaning out the throttle body and isc too if you haven't recently. seems to help a bit
Thanks a lot guys...I'll give it a go
BUILD THREAD
GT
was the car tuned in the past ?
Just slidin'
Just drive it around for a day or two, it will be fine. Its just that the ECU has reset. Nothing wrong with it, just give it time.
MD Mondeo - For the family
#8 | |||
Walking with God
GK
i`ve disconnected my battery a few times now to do variouse jobs and it seems to run exactly the same after reconnected, am i just lucky? are the battery posts/terminals clean?
#10 | |||
Resident AFF detailer
I did the same thing a while ago - took a couple of days driving (about 100kms) and everything was fine after...........felt like it had a little more grunt as well!!! Probably should do it again soon I reckon!
No longer an 'active' detailer. |
#11 | |||
BUILD THREAD
#12 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#13 | ||
Thanks again for the replies everyone...battery tested up fine, the car is gradually getting a bit better, it's ok with no a/c running but as soon as you turn it back on, it starts stalling or very low idle so we'll just keep driving it over the next few days until it comes good. Don't know whether it's BS or not, but Southside Fraud service guy reckons the ISC is a bit of a problem sometimes on the AU's after battery disconnection...time will tell.
It's strange that this should happen as I've disconnected batteries lots of times without a backup power source on EB's, EF's, EL's, AU's and BA's without the hint of a problem...I guess there's a first time for everything. P.S. Guess what I bought today? Yes, that's right...a backup power supply :hihi:
BUILD THREAD
#14 | |||
Rusticating
Territory SYII RWD, BFII RTV tray |
#15 | |||
BUILD THREAD
