Old 30-04-2009, 04:17 PM   #1
ronwest
All Bran = Regular Member
Default Jaycar speedo corrector in AU
As in title I want to assemble the Jaycar kit and use in the Ghia.
I used "search" and there are a few posts regarding it but someone mentioned it "playing havoc" with cruise control.
I pm'd a member who uses one but he's been off-forum for over a week and I was hoping to get the project underway this weekend.
Anyone got one in an AU and can confirm it and cruise control work together without problem?
Cheers...
ronwest is online now   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 04:28 PM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
I didnt even know they made one... i'll be keeping an eye out on this one...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 05:13 PM   #3
ronwest
http://www.jaycar.com.au/productView...r&form=KEYWORD
Old 30-04-2009, 07:29 PM   #4
StealthAu
If an auto you can have issues with shift points, for cruise control I am unsure but the solution to the first problem is to use two if them. One to drop the signal from the box to the dash and another to increase it back to origional signal from dash to ecu.
This may also be the solution to the cruise issue, who knows.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 09:37 PM   #5
SIKSIX
Its gone V
SIKSIX's Avatar
my brother has got one in his car because he went from 3.08's to 3.73's and it hits the limiter before it chnges gear only under full throttle, other wise its all good.
i got a manual and i got factory cruise and it works fine with it.
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
