Old 19-04-2009, 10:22 AM   #1
bcr2734
Off tap Truckie
bcr2734's Avatar
Question hand brake adjuster
does any one have a pic of the adjuster it's self. I think my ute's has a bit of wear. if anyone can post a pic would be much appeciated.
brian
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
: Another Power Installment Soon :
1968 KC Bedford
1970 Mk1 Escort GT
1980 Mack Superliner 120t: Project Puppy Dog!
AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5
bcr2734 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 10:26 AM   #2
JC
JC's Avatar
Use the search function, and look for a post by Whoosha. He has shots of everything rear brake related, all in a handy "How to".
Ford Performance Club ACT
Old 19-04-2009, 10:28 AM   #3
bcr2734
Off tap Truckie
bcr2734's Avatar
doesn't have a photo of the adjuster. I already checked
1968 KC Bedford
1970 Mk1 Escort GT
Old 19-04-2009, 11:56 AM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
Which of the adjusters do you need inside the car, or in the hub I stil have a heap of shots I never posted
Originally Posted by Riksta
Old 19-04-2009, 11:59 AM   #5
galaxy xr8
Giddy up.
galaxy xr8's Avatar
This come in very handy for me...
http://www.fordforums.com.au/showthread.php?t=11250257
galaxy xr8 is online now   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 12:13 PM   #6
bcr2734
Off tap Truckie
bcr2734's Avatar
the hub. I just went and brought a new one. i just wanted a pick of the adjust to see if the wear on the adjuster was the same as others.
It has only been adjusted 2 times in it's life. 60, 120 and now 188. Heaps of life on pads and i will look at new adjuster to see how bad the old one is. I might return new one if i can salvage the old one.
cheers
brian :
P.S I'd rather s cams and slack adjusters on heavy trucks compared to this chit!!!!!!!!
1968 KC Bedford
1970 Mk1 Escort GT
Old 19-04-2009, 02:30 PM   #7
JC
JC's Avatar
cheers
brian :
It's not the adjusters that wear out - it's the handbrake shoes. Try replacing them, and you should be all good.
Old 19-04-2009, 02:38 PM   #8
bcr2734
Off tap Truckie
bcr2734's Avatar
The shoes are brand new nearly. The adjuster is worn in the pin. I have now got alot of the marks out of the pin with a bit of emery coth. Working like a charm now with a bit of lube. Will run with old one for now and see how it goes. Keep new one in Top of tool box.
1968 KC Bedford
1970 Mk1 Escort GT
Old 19-04-2009, 02:40 PM   #9
JC
JC's Avatar
Ah, I see - the pin that runs through the middle of the adjuster. Something I'll keep in mind for next time.
Old 19-04-2009, 02:47 PM   #10
Whoosha
AU DIE HARD
Whoosha's Avatar
I know that feeling .. tighten 1/3 back sweet
Old 19-04-2009, 03:07 PM   #11
bcr2734
Off tap Truckie
bcr2734's Avatar
I only gave it a light sand and i was rite as rain. Also i grease it with Inox ( Cum Juice ) because of how light it is and also heat could be a problem in drum and with inox it would be ok, Grease i have here is for Bearing on trucks and trailers, Not light car stuff.
1968 KC Bedford
1970 Mk1 Escort GT
