Old 01-04-2009, 10:02 PM   #1
LukeyST
ST fan
LukeyST's Avatar
Default Clutch differences xr6 HP -v- VCT
Gday,
Just wondering if anyone can tell me the difference between the clutches in the HP and VCT XR6's. More to the point i want to know if they are interchangeable, as the Exedy website lists a clutch for XR6's (part number FMK-6995), but doesn't specify whether its for HP's or VCT's.
I know for sure they are different, as today when i priced genuine items i was quoted around 1100 for the pressure plate, clutch plate, and bearing for my VCT, and the bloke said if it was an HP it would of come in a kit and been much cheaper!
Also, how much would i be looking at for an Exedy OEM replacement or HD clutch kit?? I'll be making some enquires soon, but i may as well ask while im here
My car is a series 3 VCT as below.
Thanks.
2013 Focus ST in TANGERINE SCREAM
2003 Focus Zetec in COLORADO RED
LukeyST is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 04:15 PM   #2
FS5
i thought all au i6 manuals ran the same clutch.i could be wrong though...
exedy do a good aftermarket one,i thinks its called 'sports tuff ' or something.
a clutch kit should cost you around 400/$500.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 10:24 PM   #3
webby_191189
low wagooon
If its the series 3 VCT engine the EXEDY FMK-6995 is the correct one, The sports tuff clutch mentioned is the EXEDY heavy duty version FMK-6995HD. I had the HD installed last week and is a great clutch, very bitey you could say
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2009, 10:25 PM   #4
webby_191189
low wagooon
Also thats the whole clutch kit to, everything need to bolt up to the VCT, you even get a pretty white sticker
Webby
S2 AU XR6 UTE
Old 04-04-2009, 02:06 PM   #5
LukeyST
ST fan
LukeyST's Avatar
Ok thanks for the replys. From what webby said im going to assume the Exedy clutch is compatible with either HP or VCT.
Old 04-04-2009, 02:30 PM   #6
5LGhiaWgn
5LGhiaWgn's Avatar
Hmm in all Honesty I dont see what difference there could be between a VCT and HP to make them need different clutch's, they would be running the same gearbox and flywheel it would only be the pressure plate needing to be somewhat different as the VCT puts out a little more power however that couldnt warrant a higher clamp load for the clutch as its only 10kw more
5LGhiaWgn is offline   Reply With Quote Multi-Quote with this Post
