Does anyone know of any difficulties putting a sierra 5 speed in a 1980 1600 4 speed panel van? Or is it a relatively pain free swap?
cheers |
you will need an auto tranny tunnel to fit it a stock manual tunnel is to small fro a 5 speed i think
as far as i know 5 speeds fit... should probably look into it, but if i remember correctly the sierra 5 speed is like the only 5 speed that can fit in a manual tunnel.
Its basically the same box as the 4 speed with an over-drive so the extension housing is a little chunkier and the shifter hole needs to be a little further back. If you are putting it in a mk 1, you need to space the mounts to sit it lower. Use your original gearbox mount and it should fit ok.
thanks for that. cleared things up. cheers
#6 | |||
formerly PURSUIT-250
![]() Join Date: Dec 2004
Which Fords available locally do the Sierra 5 speeds come installed?
#8 | |||
that would be nil
T2 TE50 no:154 Narooma blue AU2 XR8 ute XR4 fiesta |
