Old 26-07-2008, 04:34 PM   #1
andrewl77
Default 98 GLX Mondeo Central Locking Problem
Hi all, trying to trouble shoot a problem with my central locking on a 98 GLX Ford Mondeo. The central locking works fine for 3 doors but 1 door (front passenger) does not work at all. The drivers door opens fine and sounds fine. The rear doors open but sound like the central locking is at half power. The front passengers door does not open at all, not even when you manually use the handle.
Does anyone have any ideas on the cause of this?
andrewl77 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2008, 06:07 PM   #2
Zippy7
Sorry, I am not clear on what you mean. Are you saying you cannot unlock the front passenger door at all? Like the lock has seized? Can you manually unlock from inside, then open the door? Can you use the key on the front passenger door to unlock from outside?
I think first isolate whether it is a physical lock mechanism issue, vs connection issue. Have you taken the door trim off to have a look? perhaps it is just a case of plugging/hooking something back in.
Mondeo XR5, Thunder.
Zippy7 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2008, 09:56 AM   #3
andrewl77
The door does not open at all. The key turns in the lock and does nothing. The hand will move but will do nothing.
