guys, just want to know: i'm trying to find ECU code (i'm thinking about flashing the ECU). Don't know where I can find the ECU code?
thanks roy |
do i need to know my ecu code if i want to order from dreamscience? because focussport.com and other ecu flasher usually needs the car's ecu code. if so, i don't know how to find my ecu code.
thanks |
Old enough to know better
On the Mark 1 Focus, it was printed on the ECUitself, plus a small sticker on the inside of the front door jam. Not sure about MarkII
i couldn't find any documentation about where i can find the pcm code. Even the sticker near driver's door doesn't contain 4 digits code.
........ get in contact with one of the tuners like Dreamscience, (you will need them to flash the ecu anyway) they will tell you 'exactly' what info about your car they need and 'exactly' where to find it.
