1999 Ford Fairmont Ghia
Big problem. The oil warning light on the XE is on all the time and there is oil coming out of the exhaust.
The engine still starts and runs fine though. Lack of oil pressure? |
um I dont know how to tell you this, are you siting down
its fushinked, tooled, rooooooooted NFG you get the picture for the oil to get in to the exhaust it has to get in to the combustion chamber some how weather it through the valve guids or past the rings, is yet to be determind but as your oil light blinks I'm assuming its a really tired bottum end so I'm going with rings these things will trundel along in this state for ever, I had cross flow 6 in an XC once that I used to sent the PCV vile to a 1L bottle (after the 2nd Air filter in as many weeks I desided it was the more cost efective option) and use it to top the oil up every few days and I put black tape over the oil light on the dash so it wouldnt give me the Sh!ts this continued for months till I had the time to pull her off the road and slot a Clevo between the rails It never missed it never strugeled to start it never even oild up plugs
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
In that case how much do you think it will cost to put a mild Clevealand and a new drivetrain in the XE??
let it burn
The mounts for 6 to Clevo are simple. The bracket the mount bolts to on the chassis is a bolt on bolt off thing, so no dramas there, just get some V8 ones, I think any from XA on fit (could be earlier). Disc brake diff needs to be from XE or later due to coil rear, XD and earlier are leaf (although you can mod them). I think the 6 cyl disc rear and 302 version are the same. V8 radiator. V8 accelerator cable and some loom mods, or a V8 loom.
Youll need front springs for V8. Brakes are the same AFAIK. So then its just the cost of the motor and box and gearbox crossmember (maybe), tailshaft and unis, and that varies in price like a piece of string. Obviously V8 ancillaries too. Would need to be a Black Clevo for pollution rubbish too. Im guessing though. Hope its a good XE, could be easier to find a complete one and convert it. XD would do, and just get the coil diff elsewhere. |
to be honust I would either fit a 2nd hand engine (the EB etc 4L fits with an electric fuel pump just swap your manifolds and distributor) or slap in rings and bearings, you can do them in the car on them just drop the sway bar and juck up the engine by the sump block the mounts and lif the head and sump off a quick hone rings and bearigns and she's runnen in the afternoon
So what sixes can fit in the XE??
Can the AU six fit with much difficulty? |
#7 | |||
Meep Meep
It's a XE, Ireckon you got about 20,000k left before you have to do anything about it, just keep some oil in the car.
Thundering on.... |
#8 | |||
Is the oil warning light oil level or oil pressure? |
I'm not sure if oil coming out of the exhaust is still a symptom.
It no longer is really spitting oil and on closer inspection it looks more like water+cr@p in the exhaust than oil and it also doesn't stain my driveway like oil it wipes straight off. Could it possibly a electrical problem? My alternator light kept coming on at random intervals and would turn off if I turned the lights or radio on. I did take the XE for a swim a few times lately during the heavy rain. At one point she was in so deep that my airbox filled up with water and the car stalled so I had to scoop water out and she was spluttering and pi$$ing steam for a bit so it's fair to say she went for a good swim |
Forum Director
Post it in the relevant area.
