BURN RUBBER NOT OIL
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l [SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218 ![]() ![]() ![]() ![]() ![]() ![]() |
I've actually heard you can do it.
That guy makes it sound like a video game or something lol.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
![]() Join Date: Jul 2005
Few threads on here and ford mods will tell you how to do it all for free, just search.
#4 | |||
... Fear it!
all you have to do is hold ur odo. meter down for a random of various seconds ... i'll dig up the thread for ya
MY21.5 Mustang GT
For EF/EL (taken from Fordmods.com):
The diagnostic mode can be entered by using the following method 1) With the ignition key in the off position, press and hold the Odometer reset knob for 10 seconds. 2) whilst holding the button in, switch the ignition to the on position. (Note : It is not necessary to start the car). 3) With the ignition on, press the odometer button 3 times in quick succession. 4) On the third press, hold the odometer button down, until the Seatbelt lamp is no longer illuminated. 5) The Odometer should blank out. After a period of 10 seconds, the display will flash FORD <li>6) Press the Odometer button again to go to the first Diagnostic mode To view the next diagnostic mode, press the Odometer button for about 1 second To view the previous diagnostic modes, press and hold the Odometer button for about 2 second To Exit the Diagnostic mode, hold the Odometer Button until the Odometer display returns to normal The codes and their meanings can be found HERE at Fordmods.com
2021 Mustang GT in Rapid Red | XDA-Developers Assistant Admin
MY21.5 Mustang GT
For AU:
The diagnostic mode can be entered by using the following method 1) With the ignition key in the off position, turn the Ignition Key to the On Position. 2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds) 3) Release the Odometer Button for 5 seconds. 4) Depress the Odometer Button for 7 Seconds. 5) Release the Odometer Button for 5 Seconds. <li>6) Depress the Odometer Button for 7 Seconds. You should now be within the AU Instrument Cluster Diagnostic Mode Within Diagnostic mode, there are 19 Diagnostic Screens that are available. At the moment we do not have enough information as to what all the screens actually are. To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds.<li> Meanings of the codes can be found HERE on Fordmods.com
MY21.5 Mustang GT
I can't believe people are selling this information on eBay...making money off something like that is scandalous...
#8 | |||
Now I have this peice of toast that is shaped like a suparoo badge from a XY GT, what is the openning bid........ |
Landau = GT with the lot!
Does anyone know if this works the same for BF?
