Old 24-01-2008, 02:23 PM   #1
Lachlan2228
Lachlan2228
Default Bottom end power
Hi guys,
i am an owner of a 4dr mk2 rs2000 and was just wondering how i could improve the power at the bottom end. At the moment i am running a stock engine with the standard 32/36 DGAV carb.
Lachlan2228 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2008, 03:28 PM   #2
Sterling
get ur crank and pistons balanced
and ur flywheel
and an aggresive cam and exhaust extractors help alot also.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 07:01 PM   #3
greenmk2
75 MK2 2 Door
greenmk2's Avatar
Smile
Originally Posted by Lachlan2228
Hi guys,
Go buy a lynx single side draught manifold and buy a weber or delorto. It is designed to help with torque. You could also get a high lift low duration cam. Supercharging would be the ultimate
- FG MK1 G6ET - weekender
- Escort MK2 - Weekender
http://i76.photobucket.com/albums/j5...zaicos/Z-1.jpg
greenmk2 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 10:39 PM   #4
V8falcons
V8falcons's Avatar
http://cgi.ebay.com.au/ws/eBayISAPI....MESE:IT&ih=015
You want/need these............................
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2008, 10:41 PM   #5
V8falcons
V8falcons's Avatar
And reduce flow and power,the standard manifold can flow better than some single side draught manifolds...............Be carefull
If you havent allready got them get some good quality headers and a 2 .1/4 exhaust,dont get an "agressive" cam as you power will come in late towards the rev limit on a stock engine and be a waste ,go a for a mild cam Regraph your dizzy,and then, go for twin side draughts for some nice power.
I dont really agree will just balancing to increase torque,that is more for higher revs and faster acceleration,but to get that you need to be able to feed it
AU2 XR8 ute
XR4 fiesta
Old 15-02-2008, 10:29 PM   #6
EskyCosworth
RS2000 COSWORTH
Hi guys,
Bottom end of the motor or the RPM range?
1. Bottom end of the motor. Pinto crank is Okay for 8500 RPM, the rods and pistons need to be changed to forged items. ( I made 125hp atw)
2. Low RPM torque requires improvement in volumetric efficiency in the engine - increase the compression ratio, dyno tune the car properly - but really get it to make power and enjoy. (Cossie head and 163hp atw)
3. Add a turbo (Cossie now 325hp atw)...............Look out for 400hp atw with the new upgrade.
EskyCosworth is offline   Reply With Quote Multi-Quote with this Post
