21-05-2007, 12:44 PM | #1 | ||
Firstly does anyone know if the fuel consumption is just an estimate from a table of rpm values or is there actually a flow meter on the fuel line.
And I have an 06 Focus which has an oval sports muffler on it but you still can't really hear it only when you floor it and it gets around mid rpms at which it can still be hard to hear over the sound of the engine itself. What would I have to do to get it more audible? |
21-05-2007, 01:09 PM | #2 | ||
Posts: n/a
There is a fuel flow read out. Hold down the trip button as you start the car and keep holding it in until you see TEST on the screen. Press the trip button until you see one of the values that goes from 0-200 whilst idling. Thats most likely the fuel flow.
That fuel flow i believe is determined from Throttle opening, load and RPM because if your coasting in gear it still shows 2.something of consumption when it should be 0. With the noise, I'd look at removing the second airbox from the engine bay, or at least cutting the pipe from it to the first airbox (the airbox with the filter). You get a nice intake growl. Apart from that have a look under your car and see what aftermarket exhaust components they put in. If its the standard system with a louder rear muffler, removing the middle muffler should do some good. |
21-05-2007, 02:44 PM | #3 | ||
There is no rear muffler just the stainless oval one in the middle with the pipe going out to the back.
I was expecting more sound then there is being only the one straight-through muffler. Especially after test driving one at a dealer and hearing that the engine actually makes some noise. What about places like SMB or Hi-Tech Mufflers, they do full stainless catbacks for 800 - 900 (seems a bit pricey) would they make it sound much better? No point spending much more on the exhaust if its just gonna be more of the same. |
21-05-2007, 02:57 PM | #4 | ||
Oops forgot the fuel readout.
Looking at alot of yanky sites they all seem to think modern cars get the fuel readout by measuring the injectors ontime and using that with the distance traveled. Just trying to find out if it is done by some actual measurement of the fuel (such as injectors on) or if its just all estimated from tables of data in the computer. Cos i'm wondering if you'd be able to test different fuels for their performance since but if it's just using tables to generate the approximate usage then the figure would be the same no matter which fuel is used. |
21-05-2007, 04:45 PM | #5 | ||
Actually the muffler is more like 1/4 from the end and there may be a 2nd one that I couldn't see. Thought it was just piping but looking at it from the other side you can see it's about 2.5x as round and is a long maybe 70cm long or something up in the middle.
I'm guessing thats another muffler and not an XXL cat... lol. |
21-05-2007, 09:47 PM | #6 | |||
cheers |
21-05-2007, 11:28 PM | #7 | ||
Isn't too much cabin drone with that?
Any performance catback system would get rid of that resonator and use none or a high-flow one aye? Main thing I want above all else is some idle noise cos atm you can't even tell the thing is on lol. |
22-05-2007, 10:47 AM | #8 | ||
I have the same problem and regularly stall or bunny hop the thing because I cant hear what its doing.
22-05-2007, 04:01 PM | #9 | |||
here is a clip of my system, hope this can help you http://www.youtube.com/watch?v=YkP6glspRg4 cheers |
23-05-2007, 03:11 PM | #10 | ||
Mmmmmm nice sound, getting my exhaust in a couple of weeks so hope i got just as good an idle if not better.
Must say i've stalled mine a few times since I ave a tendancy to not turn it off as soon as I stop then I forget the damn things running cos you can't hear it so I take my foot off the clutch lol. Any places in newcastle or sydney anyone can recommend to get it done? Doesn't seem to be anywhere with a system specifically designed for the newer focus yet (SMB told me a few months they'll have one) and keep getting warned off of Liverpool Exhausts. |
23-05-2007, 03:39 PM | #11 | ||
AFF Post NAZI
any local exhaust shop should be able to make you an exhaust for about 300 buckos...
just make sure you get mandrel bent stainless steel... and dont pay until you are happy with the sound and the exhaust as well.
23-05-2007, 04:06 PM | #12 | |||
Posts: n/a
23-05-2007, 04:18 PM | #13 | ||
Just keep getting told how crap they are. Ppl complaining about bodgey jobs done or having trouble if they had a problem with it and took it back to get fixed etc.
Think alot of ppl on fastfours forum didn't like them either, couple years since i looked at them so not too sure now. |
23-05-2007, 05:37 PM | #14 | |||
: Don't yell, i'm probably hungover |
23-05-2007, 07:57 PM | #15 | ||
LOL yeah I saw a post on a forum about Hitech-mufflers doing one for $900.
Everyone seemed to think it was way overpriced but then some started saying for stainless manbrel bent with 10yrs warranty its about right. Still seems expensive for just a catback but if its specifically designed for the focus and gives power as well as sound then I guess it could be worth it, waiting for a response from them to see why they charge more then other places. |
