15-04-2007, 03:45 PM | #1 | ||
[ 5L ]
my first problem in my xr8 has popped up.
when stopping, put foot down on the clutch. the revs search up and down a couple of times before they settle. sometimes it gets bad enough and the car stalls. only does it sometimes, and it still does it if i put the factory tune back on. does anyone know the problem? cheers shane.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
15-04-2007, 04:01 PM | #2 | |||
BOSS Pilot
Mine does that aswell. Not so bad anymore though. Have cleaned the throttle body, ISC valve and new air filter which seemed to have helped it a bit I think.
Luke
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
15-04-2007, 04:03 PM | #3 | |||
Back to Le Frenchy
How do you clean the throttle body in these XR8's. There is a sticker on it saying not to clean because of a protective coating but I don't know how much if any attention I should pay to that.
15-04-2007, 04:04 PM | #4 | ||
[ 5L ]
yeah i seen that sticker as well so i put the carby cleaner back in the shed.
15-04-2007, 04:05 PM | #5 | ||||
Back to Le Frenchy
15-04-2007, 04:09 PM | #6 | |||
BOSS Pilot
Oh ok must be different : lol mines a 6
15-04-2007, 04:54 PM | #7 | |||
not here much anymore
RAM 1500
15-04-2007, 06:24 PM | #8 | ||
[ 5L ]
its a sticker on the throttle body, must be with all the 70mm ones
15-04-2007, 06:29 PM | #9 | ||||
Back to Le Frenchy
Edit: btw don't you think it's time to change your avatar? :nutsycuck
15-04-2007, 06:32 PM | #10 | ||
Walking with God
It's a coating like Teflon or such that keeps the internal surfaces of the TB smooth, thus allowing good air flow dynamics etc.
GK
15-04-2007, 06:37 PM | #11 | ||||
Back to Le Frenchy
15-04-2007, 07:35 PM | #12 | ||
All Ford Club Life Member
same with my AU series 1 XR8, I used nulon throttle body and carby cleaner
did the job.
Worked AU XR8 Ute - Toy Std FG XR6T Ute - Daily Supercharged BA 6 Ute - Wife's daily 351W F150 93 XLT 4x4 Supercab |
15-04-2007, 08:36 PM | #13 | |||
Blown 5L coming
if its hunting at idle, its more then likely the o2 sensor. have you changed it since youve had it? how many ks? also just check that the leads, plugs and air filter are all ok/clean and that the fuel filter is clean (they need replacing every 3 yrs or 80,000ks) its amazing what a difference these things make to how well your car operates!!!
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
15-04-2007, 08:47 PM | #14 | ||
[ 5L ]
spark plugs, air filter, fuel filter have recently been changed, leads were checked and were still fine. havnt done the o2 sensors. its done 97,000 now,
15-04-2007, 11:56 PM | #15 | ||
power steering pressure switches can cause slow/erratic return to idle if faulty, although i haven't seen this on an AU yet... Loss of KAM (Keep Alive Memory) can cause idle dips and stalling if it has been reset (battery disconnected) - to re-train idle, disconnect battery and reconnect (if you want to clean the t/body do so now), start vehicle and allow to idle for a few minutes with a/c on then for a few minutes with a/c off, I also turn the steering wheel around a few times to activate p/steering pressure switch during this time, then take for a five or so minute drive at cruising speeds, stop-start, etc. Hopefully this helps
