Old 12-11-2006, 10:56 PM   #1
BlackLS
Posts: n/a
Default Something for the LS guys and gals
Something I thought I may as well share with you guys; with the ignition on ACC, hold the trip meter button down. Then moving the ignition to the ON position hold it in for a further few seconds. The sweeps cool! ;) Although the personality score is a bit of a concern.
Enjoy!
Old 12-11-2006, 11:03 PM   #2
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Dammit, I'll have to run downstairs to my car to try it now BlackLS...thanks
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 11:47 PM   #3
Stugots
2006 Focus LX Hatch
Stugots's Avatar
What is it? like an instrument check where the speedo/tacho needles bounce and the LCD's run through all the numbers?
Stugots is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 07:03 AM   #4
BlackLS
Posts: n/a
You'll see ;)
Old 13-11-2006, 08:43 AM   #5
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Very cool BlackLS, good to see the LS also has one ;)
2006 LX FOCUS SEDAN
Old 13-11-2006, 08:53 AM   #6
photn
AFF Post NAZI
photn's Avatar
come on guys spill it all!!!!
Old 13-11-2006, 10:07 AM   #7
BlackLS
Posts: n/a
Buy a Focus and see for your self :P
Old 13-11-2006, 10:07 AM   #8
BlackLS
Posts: n/a
I was thinking, if the EFs got it, this must also...
Old 13-11-2006, 10:48 AM   #9
Forest Bear
I don't get it.
Forest Bear is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 12:29 PM   #10
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Yeah, my EL had it too. Mine has numerous personalities :
2006 LX FOCUS SEDAN
Old 13-11-2006, 12:55 PM   #11
Stugots
2006 Focus LX Hatch
Stugots's Avatar
Cool! the bike does that everytime I turn it on.
69 times the car's been started (unless starts means something else)
Personality = 57
Old 13-11-2006, 12:57 PM   #12
BlackLS
Posts: n/a
Personality score was 57
Most of the other things I got no idea what they mean.
I think they could be failed starts, mine is similar number. Although I've done over 43,000KM
Personality score is the same with me? Perhaps is an auto box thing?
Old 13-11-2006, 01:42 PM   #13
Piotr
Non-Regular Member
Im guessing it brings up the diagnostic mode. we have it on the Fiesta too but my gauges don't go a sweep they just move about 1mm up and down until I select a different feature.
Id say Personality score is for the auto's. They have an adaptive shift pattern so if you frequently give it WOT and generally give it a hard drive the auto will adjust itself so it shifts higher and firmer while if your a granny it will shift lower and smoother. My mates liberty does it and you can notice that after a good spirited drive it will shift higher in normal driving but return to normal later on
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 04:32 PM   #14
FOCUSonTHIS
FOCUSonTHIS's Avatar
The LR has had that for ages....so it's not just for you LS people!
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 06:17 PM   #15
Uni
which one is the trip meter button? is it the one on the end of the stalk?
Uni/.
Uni is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 07:35 PM   #16
pertuan
Focus on my Focus
I've been doing that trick for ages... well.. since March when I got the car anyway. I tend to leave it in the km/h reading or RPM readings for fun.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 07:38 PM   #17
FOCUSonTHIS
Uni/.
No the one thats on your instrument cluster and resets the trip back to 0
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 13-11-2006, 11:20 PM   #18
BlackLS
Posts: n/a
LR - Odo button
LS - On the stalk
Old 14-11-2006, 01:41 PM   #19
Marshy79
Hmm still need to try this on the XR5
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 04:32 PM   #20
FOCUSonTHIS
Sorry BlackLS I thought I knew everything.....lol guess not
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 14-11-2006, 09:32 PM   #21
murph
Cool find....
Personality 57
Rom 0541
Murph
2005 Focus Zetec
murph is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 01:03 PM   #22
MikGan
so does anyone know for sure what all the different readings mean?
MikGan is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 06:22 PM   #23
Zetec20
Zetec20's Avatar
mine doesn't wanna do it... :(
: Don't yell, i'm probably hungover
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 06:31 PM   #24
Marshy79
Yeah I must be "special"... mine does a "test" but not much more.
Must try some more!
Hopefully it plays space invaders!
Old 21-11-2006, 12:30 AM   #25
BlackLS
Posts: n/a
If its any help keep holding it down when "TEST" comes up
