ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
20-06-2011, 11:40 AM | #1 | ||
Boss 335
Does the FG Factory Reverse Cam have a module to convert the video to ICC format? If so, do you sell this item and associated loom?
21-06-2011, 08:50 AM | #2 | |||
Sponsor
we have a camera kit where after fitting or before the ford dealer have to enable camera for you on color screen, we can enable here too at asl if you are local. another option reverse camera kit using an interface rgb kit where no need for a ford dealer to enable camera, if car have factory reverse sensors then this kit will not suit ur car and u will need the IDS camera kit. this kit will come with a dual input for video on color screen and also can option video leads for ur ipod iphone to be play video on color screen, cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
21-06-2011, 04:08 PM | #3 | ||
Hi Fadi75
If i was to source the factory reverse camera, would your kit then enable me to wire it back to the ICC. Mine car is an FG F6 with reverse sensors. Only reason being that i get to keep the full factory look. I understand i would need ford to enable the camera function though. Final question, if i change the boot harness to the camera model, and install the factory camera, will this then mean all i have to do is go to ford and get it enabled, or is the ICC harness different? Thanks Kind Regards Marc |
21-06-2011, 05:18 PM | #4 | |||
Sponsor
i am not too confident to say yes it will or not work if u use the factory camera, as our kit comes all plug in and play, once fitted then u will need a ford dealer to enable camera for you using their IDS. cheers fadi75
Thread Tools | |
Display Modes | |
