Old 12-12-2005, 01:49 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Sedan doors vs. Ute body
Would sedan front doors fit onto ute bodies?
I imagine they would somehow.
Reason is that I have a dented passenger door and wanted to also do a power window conversion, and figure that instead of buying all the bits and pieces seperately, that I'd just grab the entire door and get an auto electrican to wire them up.
If I came across a sedan with good doors, then I'd know if they fit on the ute.
Carless
Old 12-12-2005, 01:56 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
yes tranny ear they do :P
Old 12-12-2005, 02:36 PM   #3
TheSneakiness
Adapt or perish...
You'll never let me live that down, won't you?
Carless
Old 12-12-2005, 05:42 PM   #4
Mr Cube
Mr Cube's Avatar
sounds like a good story to be told here ;)
Mr Cube is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2005, 06:13 PM   #5
TheSneakiness
Adapt or perish...
I'll tell, but only if someone other than Tibbo answers my question...
Carless
Old 12-12-2005, 07:21 PM   #6
HLC
Audi S3
yes the sedan doors will fit on the ute.
now spill.
Old 13-12-2005, 10:52 AM   #7
TheSneakiness
Adapt or perish...
OK, OK.
I was at Racecraft's workshed over the weekend doing various bits and pieces to my ute (brakes, exhaust tip) and I'd asked him beforehand if we could change the transmission fluid in the ute.
We get to the part where you fill the box with fluid, and he has this 20 gallon drum full of transmission fluid with a pump on it. We get four pumps in before it starts indicating it's full, fluid was spilling out everywhere. It finally stopped, get one more pump in, go for the second one, and because the was so much pressure in the line, that it split, covering the underside of the ute in transmission fluid, the ground underneath and about 6 feet behind the ute in transmission fluid, and the right side of my head.
I'd never seen a man laugh so much ever.
Carless
Old 13-12-2005, 11:03 AM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
OK, OK.
Forget the story, the bold type is the good bit... bwahaha
It was dripping from you ear hahahahahahaahahaha
Damn that was some funny sh|t
Old 13-12-2005, 11:10 AM   #9
TheSneakiness
Adapt or perish...
Get back to work Tibbo... :P
Carless
Old 14-12-2005, 12:01 AM   #10
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
Au doors are expensive . electric regs are only $100ish each with a loom . you will need to change the body loom aswell (or add in a few extra wires)
complete RHF doors are around the $500ish mark
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
