06-01-2005, 05:45 PM | #1 | ||
hibernating
Alright usually with this type of thread people will say do a search.. but I can get away with it this time since I don't think this has been covered yet on the new forums!
I currently have standard pacemaker extractors at the moment and i think they arent designed that well.. they are too big. So I'm trying to decide what to replace them with (it won't be for a while yet but just looking into it). I'm tossing up between... 1. HM Headers - these look really good but the $900 price mark is a bit much! 2. Pacemaker Competition - i've heard good things about these seems like a good option, i think they have smaller primaries then the standard pacies? 3. Jim Mock Race Series - seems like a fairly good option as well. So what do you think? Anyone tried different ones of these? Anything else you would recommend? |
06-01-2005, 05:49 PM | #2 | ||
RIP...
The JMM race series are about as good as it gets.
Rick.
. Oval Everywhere... |
06-01-2005, 06:20 PM | #3 | |||
own the road
I don't have much knowledge on extractors but still on topic i looking into getting a Lukey Headers and 2.5" exhaust package.
Im sort of on a budget and can't quite afford the best, has anyone got any experience with this product? good/bad? any help would be appreciated
T3 TE50 #146 Quote:
06-01-2005, 06:35 PM | #4 | ||
RIP...
I believe JMM used Lukey headers before they designed there own. That's perhaps a good sign.
Rick.
06-01-2005, 06:35 PM | #5 | ||
Bear in mind HPC coated JMM Race series, while they generally seem to be the best, the are around the 900 dollar mark as well.
I'll be putting Pacemaker 4480s on mine. Some day. |
06-01-2005, 06:39 PM | #6 | ||
hibernating
Pacemaker 4480s are the competition ones yes? I think I like the HM ones best at the moment.. but leaning towards Pacemakers because of the price.
06-01-2005, 06:51 PM | #7 | ||
E-Series Owners Club
4480's are the comp ones.
All of the extractors you listed are really good. My view is that you would see some gains with any of them. HM Headers - I'm using these myself, so that's gotta say what i think of them! Yes, they are $900, but they are stainless steel and include a high-flow cat (normally worth $250+ by itself). The biggest drawback is that they are a bit awkward to fit to an e-series because they were designed for an AU. (The swaybar needs to be spaced out to accomodate them - not too hard to do). The primaries are smaller than your current pacies, but bigger than the other two you listed. These seem to suit a car that is worked (cam, head, etc.) rather than a standard car. Pacie Comps - These seem to be more suited to an auto, because they provide more low down than the other two you listed. They have the same diameter primaries as the Jim Mock Race Series. Jim Mock Race Series - same design as your current pacies, but with longer secondaries and smaller diameter primaries. Seem to suit both stock and worked cars, however, they would be slightly more restrictive on a heavily worked car than the HMs (regardless of what JMM say! :P) |
06-01-2005, 06:56 PM | #8 | ||
But Dave, which Pacey comps are you talking about? I'm assuming the 4480s are the ones John has? That's what I was told anyway.
06-01-2005, 07:01 PM | #9 | ||
hibernating
4480s are the competition ones.. which are sort of in a twisted shape.. if that makes sense :p
06-01-2005, 07:02 PM | #10 | ||
Last warning
yeah, 4480's are mine
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
06-01-2005, 07:05 PM | #11 | |||
06-01-2005, 07:08 PM | #12 | ||
Last warning
yeah, the old comps that i've seen actually had the 4499 part number.
06-01-2005, 07:10 PM | #13 | ||
Yep, that's the number I was trying to remember.
06-01-2005, 07:38 PM | #14 | ||
hibernating
oh ok i didn't realise there were 2 type of comp pacemakers!
06-01-2005, 07:41 PM | #15 | ||
$900 sounds like a lot for HM headers. Kenaz put a set of HM headers and full 2.5 inch system with tip on his old commodore, and i think that was about 800 with labour! I'd get some more prices for HM headers alone.. sounds a bit rich.
ohh and I got no idea on what you should get. Hope this helps. |
06-01-2005, 08:08 PM | #16 | |||
RIP...
You'd need to be producing well in excess of 250kw and 7000rpm before they became restrictive. I don't know of too many I6's like that. 1.5" primaries are all that is needed on a NA 4L, and will promote far better low down response. The only application which may need larger primaries, is forced. Rick.
06-01-2005, 09:06 PM | #17 | |||
The comps i was talking about are the 6>3>1 ones. They are the only comps available now, as the "other" comps are an older model.
I agreed that the smaller primaries are better for low end, but the HM's are not exactly huge, being that they are only 1-2mm bigger than the JMMs (i did measure the difference, but i can't remember if it's 1 or 2 mm now). Last edited by Thanatos; 06-01-2005 at 09:09 PM. |
06-01-2005, 09:11 PM | #18 | |||
06-01-2005, 09:25 PM | #19 | ||
Custom user title
grrr... just put the stock manifold back on ben.. :> and give me youre pipes instead..
06-01-2005, 09:26 PM | #20 | ||
hibernating
$900 is the price i got directly from the hm headers website.. well it was $920 or something. it does include a cat though not that i need one but yeah...
i havn't decided what i want yet.. |
06-01-2005, 09:31 PM | #21 | ||||
RIP...
1.5" primaries are the ideal size for just about any NA application, whatever the make. Rick.
06-01-2005, 10:00 PM | #22 | ||||
06-01-2005, 10:08 PM | #23 | ||
Custom user title
here we go again.. let me gues jmm has done this intesnsive testing
06-01-2005, 10:10 PM | #24 | ||||
RIP...
Sure, if you want a pro stock engine which spins to 9000rpm, and has a useful powerband ranging from 7500rpm and 9000rpm, then go for larger primaries. However in any street driven NA engine which doesn't see past 6500rpm, there are no gains to be had by using a larger diameter primary. Rick.
06-01-2005, 10:20 PM | #25 | ||
Custom user title
1.5 inch is more than likely going to be enuf for the average joe. A stock ecu wont go over 5 3/4 rpm any hows, and with the majority of us running cams around the 500 th lift mark, im prob going to have to agrea with sox which is a first.
On the dyno working with 250's which although are differnt in head desigine and cam profiles, we found there was more to be gained from longer runner length than the actual primary pipe size, we tried 3 diffrent sets, with the no name brand which had LONG primary producing more power and torque than the pacy and lukey pipes. |
06-01-2005, 10:25 PM | #26 | ||
Maybe it would take 9000rpm to make use of the extra flow, maybe it wouldn't! I DON'T KNOW.
I don't think that throwing randomly generated rpm ranges into the mix counts as facts, either :P :P :P Experience does count for a lot. And i know you've got experience (not sure how many extractors you've had though). I've had a set of Lukey's which have the same diameter pipe as the JMM extractors and i've had HM's. I know the difference, so i'm just basing my thoughts on what i've experienced with those and what i know about extractor design. Cheers, Dave |
06-01-2005, 10:25 PM | #27 | ||
Ditch the extractors and put a pump on it!
- John |
06-01-2005, 10:33 PM | #28 | ||||||
RIP...
Rick.
06-01-2005, 10:43 PM | #29 | |||
What i said is that the HM's would flow better than the JMM's if the car was worked enough to make us of the flow. and i stand by that. I don't beleive that it would require anywhere near 9000rpm to need larger extractors, but as i said earlier (and everyone seems to agree with) is that 99% of the I6's around wouldn't have the need for something bigger than the JMM ones. Cheers, Dave |
06-01-2005, 10:45 PM | #30 | |||
Seeing as how most sources I can find agree that long runners are better than short, does anyone think it is worth while cutting and welding to increase the length. I have thought about it myself, it would be real easy to do with the ones I have as well, but I cant see it making a real difference. I am sure I have seens some pics from others who have done it.
If so, how much longer? 6", 12", more?
