EB II
today the smash repairer showed me the globe on my ebII side repeater and the hole on the auIII side repeater certainly isnt big enough to fit the globe through...does that mean i have to buy the wiring as well or is there another way? Also would the hole on the ba repeater be bigger? i may have to return the repeaters i bought at ford parts ($17 each) if the BA ones fit better
windsor user
its easy as mate......
all you've gotta do is, on the rubber globe holder, trim 2 of the tabs off, and it fits perfectly into the au repeater.....then, you have to trim the long mount on the repeater a little, and it clicks into the guard perfectly... its 5 minutes work on each at the most..... i worked it all out myself and mine fit perfectly ![]() ![]() (those badges are loooong gone) |
EB II
ok so when you say "trim the long mount" on the repeater isn't that the metal bit?
windsor user
no...the repeaters are plastic
look in the pic i posted where the repeater is out of the guard.... that metal bit that protrudes into the opening is in the way IF YOU DONT TRIM THE PLASTIC ON THE REPEATER LAMP ITSELF if you do trim the repeater plastic, it will clip BEHIND that metal piece that protrudes into the hole EDIT....do you actually have the repeaters yet???? if so do yourself a favor and COMPARE yours to the one in my pic......... you'll see exactly what i mean then |
#5 | |||
EB II
windsor user
yeah it will definatley fit, if you trim off the 2 tabs
i just bit the bullet and had a go....and it all worked out fine.. just be careful you dont slip and slice your finger off but lol |
#7 | |||
EB II
Sidecutters do the job just as good.....
And plleeease put them on the right way! MADNC_8's alignment is correct.
PX3 Ranger - family truckster
BF Fairlong Ghia - boostlounge 11.26 @ 121 |
EBII XR6
mate it's such a simple job, you can do it yourself so easy!
to put the globe in, as MADNC 8 said, trim two opposite tabs off the globe holder, the orange globe will now fit in perfectly, trust me it does. a stanly knife will do this for you! ok now to the repeater part, theres 2 ways, MADNC 8's way, trim the larger tab a bit. but heres how i did mine, bend the larger tab and slot it behind the metal bit inside the gaurd, then just click the back into place. its so easy mate. it'll take you 10 minutes for the whole job at the most. if i lived in sydney i could do the whole lot for you in 2 minutes flat!
DEVLXR
#10 | |||
EB II
EBII XR6
ok i'll try to explain the second part again!!
- take the repeater in your hand - you'll see on the back of it theres 2 clips, a large clip and a small clip - leave the small clip alone, dont touch it! - the large clip can be bent backwards, dont force it tho or it'll snap! so only bend it a little for the time being - now insert the bulb hoder into the repeater and twist into place (remember to put the bulb in there first!) - now using 1 hand to hold the repeater and the other hand to hold the large clip - bend the large clip and push it behind the flat bit of metal in the gaurd (look at MADNC's first pic in this thread and you'll see a silver bit of metal in the hole, this is where you bend the clip behind) - now that the clip is behind there, push the back of the repeater into the rear of the hole and waalaa! theres also this document from fordmods.com that shows you the other way of installing these repeaters! http://www.fordmods.com/forums/documents.php?doc=76 hope this helps this time mate!
DEVLXR
#12 | |||
EB II
EBII XR6
bending the large clip wont do anything to the globe or the hole.
yeah just trim 2 opposite rubber tabs off the bulb holder, just trim it and test for fit, if it doesnt fit just keep trimming till it does fit! i'm uploading pics now so i'll post in a few minutes...
DEVLXR
#14 | ||
EBII XR6
ok heres the pics mate:
sorry about the quality, its really bright outside! you can see i have trimmed two opposite tabs off ![]() the bent large clip ![]() look closely and you can see i've stuck the bent large clip behind the metal plate in the gaurd, this can be slightly difficult, just use a finger to push it over the plate ![]() finished product ![]()
DEVLXR
#15 | ||
EB II
In relation to: http://www.fordmods.com/forums/documents.php?doc=76
am i better off returning my au3 repeaters and getting au I ghia repeaters? Apparently the au I ghia repeaters have an orange filter and are ok to go straight in whereas the auIII repeaters require new globes with an orange filter? Is this orange filter required by law? Any advice would be appreciated Anyone in Sydney who has successfully done this mod let me know as I'm willing to pay you to do it. I haven't tried this myself but there's a chance I'll stuff it up and hence land myself in more **** cheers |
#16 | ||
windsor user
the pair of orange globes are about 3 bucks, and pop straight in...
they also look far better than the au1 ones......... stop procrastinating and just fit them already...... mine went on the car within half an hour of buying them - and i had to work out how to mod them to get them to fit |
#17 | |||
EB II
#18 | ||
windsor user
got them from ford when i got the repeaters..... i dont know the part number but just go in and ask for them....they look exactly like a park light globe only they're orange instead of clear
#19 | |||
EB II
Just out of curiousity would it be illegal if I used the globes currently in my EB II? cheers |
#20 | ||
windsor user
unsure......most likley yes though as they arent orange
