Old 16-09-2009, 08:32 PM   #1
falzoony
Rockin '67
falzoony's Avatar
Default Spark Plug Advice
Anyone used denso iridiums in their 6cyl?
Was looking at these and was gonna hit buy it now but thought I should ask my fellow forum users for their opinion.
BA XR6 Turbo
'67 XR Wagon
falzoony is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2009, 08:48 PM   #2
The Monty
Just slidin'
The Monty's Avatar
They are a pretty good plug apparently, but if you go to Toyota, and quote that part number, I think youll find they are like $4 a plug, could be worth it to save a few quid.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 16-09-2009, 09:40 PM   #3
azza11
azza11's Avatar
http://www.fordforums.com.au/showthread.php?t=81894
This is my XY wagon, has been in the in the build section of Xtreme fords.
Its on a rottiserie at the moment, been sandblasted inside outside. Chassis rails moved inboard 3"s each side. Have 15.5"s room there now. Had nice convos to, (Doh stolen now) Have some RRS gear that may go in, brought the cheaper stuff first, lower control arms, billet strut caps, shock tower notch kit. Decided on BBF 557 to be exact, brought plates last night. Have to notch the towers now. Also about to buy a 4" cowl scoop. Need a bare block and power glide to dummy up.
1967 XR Falcon Wagon, Super Pursuit…….for now.
*****XR PARTS WANTED*******
azza11 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2009, 09:54 PM   #4
TE029
Blue Blooded
In my opinion cant go to wrong with the motorcraft Iriduim plugs unless it is a fairly heavily modified unit or on gas etc.
At least that way the heatrange will be spot on and the plugs will run clean,
Rather than denso iridium potentially designed and heatranged for different engine...
"Performance" iridiums are a but of a toss in my opinion as any iridium needs smaller gap and more voltage to jump than Standard plugs.
Probably get stronger spark out of standard plugs aka series 1 but trade off need to replace them every 40,000km's
Spend the money you save on a set of good quality leads instead.
TE029 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2009, 10:04 PM   #5
azza11
azza11's Avatar
Jim Mock do autolites from the states, thats what Brendan told me.
AZZA
Old 17-09-2009, 05:46 AM   #6
The Monty
Just slidin'
The Monty's Avatar
There are Denso iridiums made for our cars, plenty of people have run them before (FS5, me).
In saying that I have found no difference between a $120 a set plugs to my now $20 a set plugs.
I get my plug leads from QLD ignition leads. Made to order, 9mm spiral wound core, in any colour, $85, and they will post as well.
Old 17-09-2009, 10:42 AM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
QFT. Best leads ever. I run them on all my cars, so do my mates, so does my brother. Best leads ever.
Old 17-09-2009, 04:20 PM   #8
Mechan1k
Mechan1k's Avatar
In the end with mucking around with plugs for a while ... i ended up going back to standard plugs ... in an EGAS engine.
The reason being there was little to do difference in them ... except the price .... and they are pretty eas to change .. it worked out cheaper to replace standard plugs every 50,000km (I could get actually get that much out of them on LPG) .... than to replace Iridiums every 100,000km .... and sometimes they'd need replacing prior to that.
As for leads ... QLD Ignition leads are excellent as well for the $$$$$.
Old 17-09-2009, 06:00 PM   #9
ronwest
All Bran = Regular Member
Yep... I use them as well
Old 17-09-2009, 07:20 PM   #10
azza11
azza11's Avatar
I am going to buy a set of the QFT leads.
AZZA
Old 17-09-2009, 07:27 PM   #11
GK
Walking with God
GK's Avatar
On both my AUs I use stock NGK plugs and change them once a year. Cheap and easy to do. They both run stock leads also.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 17-09-2009, 08:20 PM   #12
The Mighty Red
The Mighty Red's Avatar
i have had the autolite plugs from jmm in our xr6 for over 4 years and they are still going strong........... obviously now i have typed this one will crap itself any day lol
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
