07-01-2011, 07:30 PM | #1 | ||
Hi, changed the oil recently on my AU1 4.0l. I noticed a small leak from the sump plug so bought a fibre washer and put it on, but the washer broke (I wasn't really twisting that hard either).
Anyway, as I was trying to temporarily put the bolt back in, it wouldn't go all the way in and I noticed some metal spring poking out of the hole. Probably a helicoil that mechanic had put in in a previous service. I've put the bolt back in but not all the way. Not sure what to do now, because I wouldn't have a clue how to remove the old helicoil and perhaps replace it. Would it be an expensive job for a mechanic? I have searched, but most threads relate to fixing a stripped thread. Would be grateful for any suggestions. |
07-01-2011, 07:38 PM | #2 | |||
Falcon Unbelievable!
Biggest tip that I was given was to tighten the plug first to break the vacuum then loosen it off. Comes off nice and easy after that. Good luck amigo |
08-01-2011, 12:11 AM | #3 | ||
When in doubt, GAS IT!!
14-02-2015, 08:29 PM | #4 | ||
cost me $240 my mechanic got a mobile thread repair bloke in he did it without undoing the engine mounts somehow
14-02-2015, 08:32 PM | #5 | ||
cost me $240 for a mobile thread repair bloke to come and do it he put a new helicoil in but it still seeps oil
15-02-2015, 03:55 PM | #6 | ||
XR6T BA 2002
I bought a sump 12mm sump plug bolt that tappers out to 12.8mm
used 2 sump plug washers originals they strip pretty easy you only meant to tighten them to 15nm as per the workshop manual
XR6T 2002 BA
15-02-2015, 05:06 PM | #7 | ||
Maybe try some Loctite aviation gasket sealant no:3. (The non hardening one)
Put some of that on the thread & around the O ring seal / washer, hopefully that'll stop any leaks. |
15-02-2015, 11:21 PM | #8 | ||
or you can go to ford and get a no. 1 or no. 2 or no. 3 over size sump plug and a tap dependent on what you need and do the job that way.
17-02-2015, 01:31 PM | #9 | ||
I use a plastic washer and thread tape on mine,never leaks.
