08-11-2005, 08:05 AM | #1 | ||
Hey guys,
This month ill be using the EA to tow my other car from Melbourne to Shepparton for the spring car nationals. Just wondering if anyone here has experience in towing with the ford T5, any tips/tricks? I was thinking it might be a good idea to leave it in 4th rather then 5th on the freeway to save 5th the hard work. Is this nessacary? Only thing is that the engine will be up in the revs a bit at 110km/h and 3.27 diff, so 5th would be nice. So yeah, any tips would be good. |
08-11-2005, 08:41 AM | #2 | ||
OzECruisers Treasurer
Towing a big load 80km leave it in 4th
08-11-2005, 09:01 AM | #3 | ||
^^^^^^ What he said ^^^^^^ 80km/h tops with a big load on (1200kg+ including the trailer weight)
08-11-2005, 02:02 PM | #4 | ||
its not a!
110kmph with that load is VERY scary if there is a crosswind, i know..
80kmph in 4th!
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
08-11-2005, 02:05 PM | #5 | ||
Last warning
deffinately keep the speed down, after witnessing cars getting speed wobbles carrying loads, screw that!!!!!!
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
08-11-2005, 02:22 PM | #6 | ||
Two > One
80kmh isnt as bad as it sounds. We trailered a car From Geelong to Adelaide at 80kmh. Wasn't exactly fun, but wasn't TOO bad.
08-11-2005, 02:25 PM | #7 | ||
Mopar/No Car
I'd say I've driven probably 2000k's with car trailers/horse trailers in the last couple of years. Just get in to it - if you start getting speed wobbles or crosswinds, just take your foot off the go pedal and ride it out. Don't brake hard, as this will cause an accident.
Remember - a Falcon is a relatively big, heavy car - it's not like towing behind a Mighty Boy. The T5 should be fine in 5th, providing you don't change up until you're up over 100. This is the advice I've got from several people who regularly tow big loads with the Ford 5 speed.
ColumnShift Media '72 Plymouth Scamp '80 Courier '13 Kawasaki ZX14-R '13 Berlina '92 Suzuki DR650 If you don't fight - You lose
08-11-2005, 07:24 PM | #8 | ||
Used to tow a clevland powered Capri with a 5spd EB XR8 and used 5th gear no probs. As for this 80 kmh stuff, should only need to go slow if your trailer and or weight distribution is not right. Have been towing cars on trailers since I got my licence at 100 or over without incident when its setup properly.
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo |
08-11-2005, 07:47 PM | #9 | ||
I've also been told 5th gear is alright aswell aslong as your already up too speed and just cruising, always kick it back a cog when you need to accelerate and you'll be sweet.
Ed |
08-11-2005, 10:48 PM | #10 | ||
hey simon, ur actually going up there again? Reckon it'll be any good after last year? The cops were all over the place and crowds were well down. When is it by the way?
08-11-2005, 10:54 PM | #11 | |||
Cuban... nothing like it
Invest in a weight distribution hitch...
Towed the ts to Wagga Wagga and on some blood woeful roads sitting on 110 without a drama.. No Sway, No Dramas
09-11-2005, 08:27 AM | #12 | ||
Thanks for the input guys.
I think i'll just have to go by feel. If she starts getting the wobbles, ill slow down. I have towed with dads EL auto at 100 without any issues, its just the T5 that was concerning me. I guess ill leave her in 4th if im under 100, or going up a hill or something. As for the trailer setup, I normally try to place all the weight to the front of the trailer, correct? Doug, im guessing the crowds will be down again this year, but should still make a good weekend. I wont be taking the car off the trailer unless its at the track, so unless they go through the, I should be right. Its on this month 25th 26th 27th. Simon |
09-11-2005, 09:43 AM | #13 | ||
Mopar/No Car
Yep - weight should go to the front of the trailer. Another key thing is make sure the car on the trailer is DEAD STRAIGHT... I loaded an engine-less ZH on to a trailer once, jammed with the front of the car to the left and the rear to the right, diagonally across the trailer... Scary on the road.
09-11-2005, 10:14 AM | #14 | |||
09-11-2005, 10:46 AM | #15 | ||
It will depend on the weight of the towed vehicle and placement of the trailer axles. Trailer I used was setup so no matter what car you put on it it went right to the front. As Laminge said get a weight hitch and get it setup properly then no worries what ever speed you want to do.
09-11-2005, 11:34 AM | #16 | ||
Ok guys, I think the thread is about the T5 and towing, and not how to tow...lol
Well, I tow every day with a T5 equipped Falcon, and can tell you, they are not the best for the job. Basically NEVER EVER select 5th gear under 100kph. And I mean never. What it does is overload the box, due to overdrive overun and heats the box up significantly. As you are aware, the T5 uses ATF fluid for an oil, and not the old 90w gear oil used in gearboxes of old. The problem here is that ATF breaks down above 90 deg C and starts to act as water, not a good lubricant. Heat is the major enemy of the T5, and the case grows about 80 thou under heat, which unloads the bearings, and causes premature wear, and subsequently failure. I have 3 boxes here, and just rotate them as noise starts to appear. It is generally the lay shaft bearings that go first, and you will hear a slight rattle in the box at idle. Just keep full throttle applications to a minimum, and remember to let the box keep cool, and you should have no dramas. Matt |
