Old 04-03-2006, 03:40 PM   #1
perthtx5
Default fan switch/ac
Hi i am new to this site and have read quite a lot of problems that people have had with there telstars which will come in handy if they happen to me.
I currently have a problem with my 88 telstar tx5 ghia, when i switch fan on to position 1 or 2 the ac compressor kicks in but no fan speed, when I put it to 3 or 4 fan cuts in but ac compressor turns off. I pulled the unit out of dash thinking it may be worn connectors, there is six wires running into the fan speed box 1 for each speed ,earth & power i presume, there is power to possistion 3 & 4 but not 1 & 2. So i hope somebody might point me in the direction i should be looking as everything else seems to work like it should.
It also might be the fan motor itself but i cant find where the power for 1 & 2 comes from.
Cheers for any help!
perthtx5 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2006, 11:01 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Wink air con problems
maybe a gas leak in the air con system
or the switch needs replacing sent you a pm anyway
My car goes Brumm Brumm
Old 11-03-2006, 07:57 PM   #3
jonzo
Default Similar Problem
Hey guys, I have a similar problem, I thought that by now you might have some insight into solving it.
My problem is that my fan was going perfectly well (I don't have a/c) then one day it just stopped working. I know that it's not the fan because I connected it directly to the battery and it goes well, I've checked all the fuses - they were fine, and I've had a look at the switch which didn't seem broken (worst comes to worst, I might just try putting in a new one, but I want to put it off for now).
My question is: Is there any other things in the heater/fan system that just die without warning? Someone mentioned a fan resistor that I might try to find... and I'm unsure about relays (there is a 'blower' relay and a 'cooling fan' relay, i'm unsure which is refering to the fan on the radiator, and which is the internal fan, and no idea how to test them).
So yeah! i'm pretty stumped. Any advice, suggestions, or even just random guesses much appreciated!
Cheers.
jonzo is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2006, 12:26 AM   #4
Scareybear
GRRRR.....
Scareybear's Avatar
with the relays, swap them over to test them, the 'cooling fan' is for the radiator, I'm not sure about telstars but holden fan resistors go all the time.
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit.
Gone but not forgotton - Diamond White 2004 LX Fiesta
If you sneeze with your eyes open, do your eyes pop out??
Old 17-03-2006, 08:16 PM   #5
perthtx5
Hi Jonzo i just had my fan speed switch fixed, the auto electrician replaced a faulty resistor, he put a second hand one in but he said new price was about $149 plus fitting.Not quite sure where the resistor goes but it has three plugs on one side and 4 elements on the other side (like a kettle element).
Hope it helps
Old 17-03-2006, 09:02 PM   #6
bmbentley
on my oldies KF laser, 1 did not work then 2 didnt work, then 3 didnt work, then it worked again, now it doesnt, neither does 4.
this car does not have aircon.
another fault is the interior light, always blows bulbs if u leave it set on door.
ok car but plenty of minor faults
bmbentley is offline   Reply With Quote Multi-Quote with this Post
