Old 08-11-2006, 02:53 PM   #1
cue
Default capri master cylinder upgrade
hey all
I have vn calipers and borg warner drums on my mark 1 capri
I want to put a larger master cylinder on the car
does anyone know of anything that will bolt up easily that has a larger internal bore?
cheers
Quinton
cue is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 03:27 PM   #2
Jim5_0
Apparently you can use one off a Rover SD1 or even a Range Rover so I have been told. 1" bore & a bolt on fit.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 06:04 PM   #3
mr scotto
mk 1 capri
mr scotto's Avatar
apprently one of a centura will bolt up to a 4 cyl booster and run a four wheel disc brake setup.not what you got but a bit of useless info.
source-hoppers stoppers
mr scotto is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2006, 08:05 AM   #4
whooligan
whooligan's Avatar
Yes, think big british cars of the same era. Land/Range Rover, I know for sure fits. I think you can even use one from a Jag.
whooligan is offline   Reply With Quote Multi-Quote with this Post
