Old 05-11-2005, 12:04 AM   #1
mattbl
mattbl's Avatar
Exclamation Brake disc question
I've had the car about 6 weeks now and and now starting to tinker around a little bit.
The handbrake shoe was sticking to the disc a bit on the right rear and making that horrible squealing sound. I printed out the instructions on how to adjust the handbrake but came up with the following problem:
The inspection hole on the disc doesn't line up with the inspection hole on the hub so you can't adjust the handbrake without taking the disc off.
The problem with that is you either don't adjust it enough and it brake doesn't hold or you over tighten it and you can't get the disc back on.
Sitting here thinking about it, is it possible the guy that had the car before me put the discs on *** about ie. left on the right and right on the left? The hole for the securing screw lines up but not for the inspection hole that has the rubber grommet.
Matt
mattbl is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2005, 12:17 AM   #2
Lightning Strike GT
Lightning Strike GT's Avatar
Yep that is a possibllity of the L on the R and R on the L
The inspection hole should be under the bung and it should line up easy to poke a screw stick thru it to back off or tighten the hand brake adjuster
Trust me I dicked around for a few months to eliminate the dreaded squeek and ended up taking it to FORD and within 1 hour is was fixed all properly aligned and adjusted and it now works
It was just under $50 - best money spent on the car
Alan
Regards Alan
FG GT in Lightning Strike
5th anniversary edition in manual 1 of 25
And an 2019 MD Mondeo Trend Wagon in Platinum White
Lightning Strike GT is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2005, 12:29 AM   #3
JC
JC's Avatar
Jack up the back of the car (both wheels off the ground), chock the front wheels, put the car in neutral and leave the handbrake off. Then rotate the disc/hub assembly until the inspection hole lines up.
Ford Performance Club ACT
Old 05-11-2005, 12:34 AM   #4
HLC
Audi S3
we've had our Fairlane in Ford constantly trying to get the Handbrake fixed but they cant get it right. now its basically useless. but it doesnt squeel...
on my car its getting progressively worse. next service im getting it rectified.
Old 05-11-2005, 12:45 AM   #5
mattbl
mattbl's Avatar
That's the problem the inspection hole doesn't line up.
I'm replacing the coil springs this weekend, while I'm doing that I'll remove both rear wheels at the same time and inspect the discs to see if they are on the wrong sides.
I prefer to do all work myself and only go to the mechanic if need specialised tooling etc.
Old 05-11-2005, 01:06 AM   #6
JC
JC's Avatar
There's no way it can't line up. Even if you managed to get the discs on the wrong side, they would still line up as much as they are supposed to. It is awkward adjusting the handbrake - if it was easy, everyone would do it!
Old 05-11-2005, 03:10 AM   #7
mattbl
mattbl's Avatar
Nope
The hole on the disc is nowhere near the hole to adjust the handbrake.(at least 5cm further around)
I'll take a picture of it on Sunday when I take it apart
2006 BF Egas XR6 Ute. Bone stock - Sorry Fellas I've had a set of King Springs in the garage for 12 months who knows when I'll get around to putting them on :
Old 05-11-2005, 09:02 AM   #8
Casper
Contributing Member
Casper's Avatar
Nope
I thought I was insane till I read this.. mines the same Matt. I would have to remove the disk to get to the adjuster.
Older, wiser, poorer.
Old 05-11-2005, 10:18 AM   #9
JC
JC's Avatar
The adjuster is static - ie is part of the brake system that doesn't move. The hole moves with the disc. If they don't line up, just rotate the disc until they do.
