07-01-2005, 01:23 AM | #1 | ||
Oops, I slipped....
Hi Guys
I recently had an encounter with a gutter, which resulted in a fair bit of damage to one of my rims, as well as the K-frame, castor rod, lower control arm, stub axle, wheel bearing and both ball joints. The K-Frame needs to be replaced, and my first question is what else fits the EF V8's? Is the 6 & V8 one the same? What about the other suspension parts, are all EF-EL parts interchangable?? Thanks
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
07-01-2005, 09:02 AM | #2 | ||
Last warning
the only difference re V8 suspension differences was the springs were stiffer IIRC.
no idea with the kframe but i'd say any I6 parts could be used to replace *most* of the suspension.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-01-2005, 09:37 AM | #3 | ||
Ute Forum Moderator
Go the AU2 conversion!!! That is, if you're willing to be the guinea pig.
07-01-2005, 09:39 AM | #4 | ||
Last warning
GOod idea ;)
07-01-2005, 11:16 AM | #5 | ||
Virtuous Bogan (TM)
yeah know that feeling.
im not sure about the interchangablity of the k-frame but i do know that a V8 sway bar fits an I6. Now I know that is totally useless to you but hey...someone might want to know.
07-01-2005, 02:09 PM | #6 | |||
07-01-2005, 02:12 PM | #7 | ||
Last warning
there has been some mention that AU suspension components may fit and thus AU2 brakes coule be fitted (a VERY handy options) aswell as having AU wheels at your disposal... but then you still need to work out the rear end ;)
07-01-2005, 02:15 PM | #8 | ||
PM me if you want
I thought the AU IRS rear end was not an overly hard mod to do, didnt walkinshaw do it, or i have just posted alot of crap
07-01-2005, 02:16 PM | #9 | ||
Last warning
no one here has done it, but as you said apparently its not that hard.
with i think only 1 or 2 mounts needing to be added.
07-01-2005, 02:34 PM | #10 | |||
Ute Forum Moderator
I don’t know if it has been done or not. Re the rear IRS, if my memory is correct the AU IRS weighs 70kg more than the live axle which is certainly something to consider. |
07-01-2005, 03:21 PM | #11 | |||
Oops, I slipped....
It is a good time to do it though, as I need to replace most of what I need to change for the AUII conversion, and I need to replace the rotors, change the pads and rebuild the calipers soon anyway..... I'm not too sure on what i'll do about wheels if I go ahead with it. One other quick thing, does anyone know the model of this wheel, or know someone who has one for sale? Thanks guys.
07-01-2005, 05:35 PM | #12 | ||
I don't know what type of wheel that is but shit that is one hot lookin fairmont. That would be nearly the best one I have seen. Is this yours Aaron?
07-01-2005, 05:39 PM | #13 | ||
Ute Forum Moderator
Raptor would be the best person to ask, but here is a list although I can’t guarantee it is complete!
All front suspension components (upper & lower control arms, spindle, sway bar) All front brake components (including hoses) Front alloy crossmember (which has different bolt and pin locations on the chassis rails) Steering rack Engine mounts If AU offset wheels cause a problem with the standard rear axle you can apparently swap an AU live rear axle easier than the irs. |
07-01-2005, 06:39 PM | #14 | ||
windsor user
the **** end is easy to convert to AU spec, the live axle diff bolts straight in
irs has a frame that mounts to the lower trailing arm mounts on the front and 2 brackets need to be welded in at the rear ( they are spot welded to the chassis of the AU, unpick the welds and weld em in the same place on the EF) |
07-01-2005, 06:43 PM | #15 | ||
Two > One
Dont give Aaron ideas lol. An IRS and AU2 break equpied EF would go (and stop) quite nicely come to think of it.
07-01-2005, 06:46 PM | #16 | |||
Burnin Rubber
Go the AU2 conversion, come on, you know you want too.
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
07-01-2005, 08:51 PM | #17 | ||
Oops, I slipped....
Gambit - Thanks, yeah it is my car.
I'm seriously thinking about the AUII conversion, but the 2 main things that are a concern is the crossmember has different mounting points, and the steering rack needs to be changed, and i'm guessing both parts would be very expensive. Any ideas on prices for the 2?
08-01-2005, 01:21 AM | #18 | ||
its not just the alloy crossmember that you need to hold the rack from the AU but you will also need the very front crossmember that is also the pivot point for the lower control arms
personaly i dont thinks its a worth while conversion i would stick with the standard front end one other thing you will need to concider is the relationship between the engine mounts on the alloy crossmeber & the centre of the stub axle compared to the original setup you have at the moment just my $0.02c worth regards rod |
08-01-2005, 09:20 AM | #19 | ||
windsor user
i know of someone that did the oposite conversion, he fitted an e-series K frame to his AU XR8 rally ute. mainly for the extra offset, but also because he had the sorted and braced front end from his previous rally car ( an eb) so it saved him having to re-work out stuff
he said that the AU front end into an e-series wouldnt be hard at all, most of the stuff lines up, only needing slight mods to get it to actually fit. im unsure of what needs to be modded though |
09-01-2005, 02:29 AM | #20 | ||
The AU IRS is almost a direct fit from what I've read. As others have said a couple of minor things have to be welded in (and the tail shaft changed for EA) and you're set. The AU setup weighs about 90KG more than the live axle though which is a huge downside.
The front end I'm not so sure about. I'm pretty sure it's very different, I don't think anyone's mentioned this but I'm 80% sure the A-arm in the AU setup mounts up differently. If it were me I'd just be looking at replacing all the damaged suspension components for now, and replacing the K-frame later. All the stuff you've written wouldn't take more than an hour to change over. Infact if you had an EA I'd be able to give you all the parts lol. If you're going to change all that over you may as well do the other side stuff as well, but then again you're K-frame is bent lol...so it wouldn't matter! Sundeep Last edited by Sundeep; 09-01-2005 at 02:31 AM. |
09-01-2005, 02:53 AM | #21 | ||
Why would you change to the AU front only? Not only would you need two different pairs of wheels, you'll be stuffed if you get a flat. What are you going to do, carry two spares?
Now I can understand doing both front and rear, but it would be a fair bit of work. But I wouldnt mine doing that conversion, but not to my ED. Perhaps the Fairmont wreck I have as a practice....
09-01-2005, 11:22 AM | #22 | ||
windsor user
martin, do it to the fairmont be a guinnea pig, i would have a go but i dont have any money to waste if it wasnt gonna work out......
as i and others have said, the rear is the way easy part, its the front thats the problem:P the AU live axle will BOLT IN to an EF or you can spot weld the 2 brackets in and fit the IRS:P |
09-01-2005, 08:19 PM | #23 | ||
I wouldn't bother with AU stuff. It would be harder to find more explensive etc.
I know how ya feel thou mate, here is my steering rack. It's out of the car now sitting on the garage floor. :( : :togo: Last edited by Damo; 09-01-2005 at 08:21 PM. |
09-01-2005, 08:24 PM | #24 | ||
windsor user
shit how'd that happen damian
09-01-2005, 08:24 PM | #25 | ||
Did u find anything else wrong with it Damo? Was a pretty nasty encounter....I should know ****en.
Sundeep |
09-01-2005, 08:47 PM | #26 | |||
09-01-2005, 10:14 PM | #27 | ||
haha, yeah it's all good. I hope. Looks like the mounts clean snapped off the K-Frame, nothing else looks bent.
oh and a small dent in one of the tickfords.. : i'm still a bit shook up. Thanks again Sunny, for stopping. I was in shock.. Hopefully a new rack will bolt up, i'll get it all aligned, and away i go. Oh and thanks to my champion brother Kenaz, for helping me pull the steering bits out and survey the damage :(.. not to mention coming and picking me up. oh, and sorry Aaron, i hope you can get your beast sorted as easily as possible. |
09-01-2005, 10:19 PM | #28 | ||
Custom user title
id def just stick to the ef front end arron......
09-01-2005, 10:34 PM | #29 | ||
No worries lol. You're just lucky no one called the cops and you didn't hit anything else.
Sundeep |
